SR length contraction question
ehasan
A rod moves along x-axis with speed u and has length L relative to Inertial Frame S. What is its length L' relative to the other inertial S' that moves with speed v with respect to S.
I know the famous length contraction formula L=L' * sqrt(1-square(v/c))
but I confuse how to include velocity of the rod (u) in this formula...:confused:
thanks
The speed of the rod relative to inertial system S' would be (u+ v)/(1+ uv/c^2)[/math]. Put that into the contraction formula rather than v.
<br /> <br /> Thanks a lot for making it clear to me
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
