How Do You Calculate Probabilities for Multiple Coin Tosses?
  • Thread starter Thread starter gtpdriver
    Probability
To calculate probabilities for multiple coin tosses, start by listing all possible outcomes, which total eight for three coins. For the event of all coins showing heads, there is only one favorable outcome. To find the probability of at least one tail, consider the complementary event of all heads, which simplifies the calculation. For exactly two heads, count the favorable outcomes directly from the list. Understanding the principles of independent events and using addition and subtraction for overlapping probabilities is crucial for accurate calculations.
gtpdriver
Im just starting probability and need some help. I have a question in my text that i can't figure out.
Three coins are tossed at the same time. Find the probability that
a) all come up heads
b) at least one comes up tails
c) exactly two come up heads
I know that the total possible outcomes is 8 but i don't know how to figure out the outcomes of the event.
Thanks for any help!
Adam
Mathematics news on Phys.org
Hi, since there are only 8 possible outcomes, why don't you start by writing down all of them and see how often each event occurs? Once you've done that, see if you can come up with a more clever approach that will work for more general circumstances.
For the first part,i'm sure you realize that there are independent events involved...
What is the number of favorable outcomes for points b) and c)...?
Daniel.
P.S.The problem is so simple,you can even count them...But that's only for checking your logics...It could have been 100 coins being flipped at the same time... :-p
Yeah I figured it out after i posted the question...oh well.
Thanks anyways
Remember, if multiple events need to cooexist, multiply their probabilities together (similar to an "AND" gate in programming) and if either goes, add their probabilites (similar to "OR" gates)
No no no. If either goes, add their probabilties and subtract the AND. Otherwise you count the center twice.
A and B = A + B - (A or B)
Check out a Venn diagram for a better idea of what's going on.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
