MIA6 said:
In my book, static friction means The frictional force that must be overcome to start one surface moving over another.
Careful here. The force that must be overcome to just start something sliding is the
maximum value of the static friction. But static friction can certainly be lower than the maximum value. Imagine a block resting on a table. You push it sideways with a force of 0.1 N and it doesn't move. The static friction is thus 0.1 N. Push it harder and the static friction will increase to compensate--up to some maximum value.
Kinetic friction means the force that opposes the motion of one surface over another.
Friction opposes
slipping between surfaces. If the surfaces slip, then you have kinetic friction. (If they don't slip, it's static.)
My teacher said that a wheel rolling is a static friction, and it's weaker than sliding friction. She likely said that sliding friction was kinetic friction. I don't understand why rolling is static friction.
As long as the wheel rolls
without slipping, the friction is static. And that can be quite low.
In my opinion, I think static friction is a friction when an object just starts to move, and kinetic friction is when the object is moving.
The friction will be static as long as the surfaces do not slip or move with respect to each other; Realize that the bottom of the wheel (where it makes contact with the ground) is
not moving with respect to the ground.
ANother thing is if rolling is static friction, then it will not be weaker than kinetic but stronger.
Generally, between dry surfaces, the value of the kinetic friction is less than the
maximum value of static friction. But realize that static friction can have a value from zero to the maximum, depending upon the situation.
For example: If you had a perfect nondeformable wheel rolling with constant velocity on a perfect, horizontal surface the amount of static friction acting would be zero! Can't get much lower than that.
Another example: In your car you step on the brakes, trying to stop as quickly as you can. If you can keep your brakes from locking, and the tires rolling without slipping, you can use the
maximum value of
static friction to slow down the car. But if you lock the brakes and the tires start to slip, the weaker
kinetic friction acts--now you have less force with which to slow down. (That's why locking the brakes is bad!)
