How Does the Statistical Interpretation Address Quantum Interference Effects?
Quantum River
I thought Statistical Interpretation of quantum mechanics is a very good alternative besides the orthodox interpretation. But I just can't explain the particle-wave duality from the statistical point.
How could the Statistical Interpretation explain the interference effects in the Quantum mechanics?
Forgive me my ignorance but the p/w duality is described by statistics per definition. I mean, if you look at the dubble slit experiment, the probability of a particle "passing through both openings" is NOT equal to the sum of the probabilities of "passing through one opening" (while the other one is closed).
Conclusion : the classical additivity for probabilities does no longer work here ! That is the entire point of the p/w duality. Statistics are an inherent part of this concept from the beginning on.
marlon
Perhaps I could be of service here. Let's illustrate the idea on the double-slit experiment.
Single electrons (i.e. one at the time) pass through a screen with two slits and hit a
detector that tells their positions. One electron leaves one spot on the detector. There
are no waves.
After the detector collects many spots a pattern in their positions appears: the interference
fringes.
Does this emergent pattern mean that electrons are waves?
Not at all. It means that there is a correlation between all the electrons.
How can they be correlated if they have never been in contact with each other, you may ask?
The preparation procedure of the electrons is common to all of them. They all are
prepared in the same way. And this preparation procedure is responsible for the correlations.
If one prepares the electrons in different ways, no interference fringes will show up, in general.
Cheers!
I don't think this is a very good conclusion. First of all, one should not be asking the question whether electrons ARE waves. This is NOT what the double slit exp tell us. It tells us that particles can BEHAVE like waves. the interference that is shown is a typical wavelike behaviour in classical physics. Particles do NOT exhibit this type of behaviour in that particular physical regime. However, the double slit exp proves us that on the atomic scale, particles (as defined in classical physics) DO exhibit this wavelike behaviour that we defined in classical physics.
Also, what do you mean by saying "the electrons are correlated" ? How are they correlated ?
Cheers!
Are you saying that the outcome of the double slit experiment depends on how the electrons are prepared ? If you look at the formal description of this experiment in any intro QM book, can you tell me what they say about "electron preparation" ? Finally, what exactly do you mean by "electron preparation" ?
regards
marlon
Cheers!
Ohw, do you have experimental evidence to back that up ?! I mean, you have some hidden messengers in mind here I guess which communicate wheter both slits are open or not depending upon outcomes of previous measurements ?
What is the very good conclusion, my dear physics guru?
And which particle behaved in such a way? In my eyes no one. The interference shows up
on the level of an ensemble of electrons. No single electron has been captured behaving
like this.
I don't know what you are writing about. The original question had nothing to do with
classical physics and as far as interference is concerned one can do without.
The probability of finding a spot in some regions of the detector is greater than in others.
By the "correlation" I mean that all the electrons where drawn from the same probability
density (i.e. a single particle correlation function) which in turn is determined by the
incident electron preparation procedure.
Yes. I'm saying precisely that.
One more example that reading without understanding has no use. Check out
the electron preparation procedure in the Tonomura experiment (A.Tononmura et al. ,
Am. J. Phys. 57, 117 (1989)).
Since you seem to like classics check out what has to be done to observe fringes in
the Young experiment with a white light source. Or better yet try to do this pretty
old experiment on your own. Is it possible to see fringes there with the use of only two
screens (one with the slits and one as a detector), my guru?
Or, perhaps, I should not be asking this question either?
Cheers!
Hi Careful,
Yes, I do. The electrons have to be selected very carefully. For example, if their momenta
vary too much the interference fringes go away. This is because incident electrons with different momenta give interference fringes in different places.
More the colimation of the beam of electrons has to be good. Take a look at the
figure 3 in A. Tonomura ..., Am. J. Phys. 57, 117 (1989). It shows what it takes
to prepare the electrons.
Another example are experiments with light. It is very easy to see fringes if you have
a laser at your disposal. With a white light source it is not so simple.
No messengers in mind :).
Cheers!
marlon, see Sakurai Ch.1 Section 1.4 and Ch.3 Section 3.4 for preparation of a pure ensemble (unless this is not what zbyszek is referring to).
The one i gave you.
I am not talking about one single particle. Remember that in my very first post in this thread, i clearly stated that the "statistics" are inherent to the double slit experiment. So for me to be talking about one single particle, would contradict my own words.
What i said was that on the atomic scale, EVERY particle exhibits wavelike properties. The socalled duality does not apply to certain particles and not to others. One can replace the electrons by photons etc etc...The outcome of the double slit exp would still reveal the same kind of information.
like this.
But I WAS talking about ensembles...STATISTICS remember...
Actually, what i wrote there is the ONLY and correct way in which you should interprete the p/w duality. We don't call this atomic scale behaviour a DUALITY between waves and particles for no reason, you know.
One does NOT need all that to properly describe the particle wave duality and how it can be shown by the double slit experiment.
Well, my point is that within the context of this thread, that is not the key aspect because you don't need it to describe the duality.
For that matter, check out how the double slit exp is introduced in Bransden and Joachain's INTRO TO QM.
Again, i know what the experimental requirements are, but that is NOT what i was talking about. I already told you that i was objecting against the way you look at the actual duality (ie the point i made, to which you so eloquently replied "i don't know what you are talking about").
LOL...This is irrelevant. I am not talking about "white light" versus laser light etc etc. i know what happens with each light source. You are missing the point : in the case of the double slit exp, the formalism is important and is very clear. I objected against your interpretation of what happens with the "particles" in the double slit exp.
Cheers!
I dunno...
Cheers
Cheers!
So, what do you have in mind then if I may ask ?
Careful
Thank you for your patience, my guru! Let me ask for some more, please.
Your are not talking about any single particle, right?
Still, "EVERY' one exhibits wavelike properties. Is "EVERY" somewhat different from 'every'? If it is not, then can one infere from the above that each particle behaves like that? If this is so, could I humbly ask about the source of such wisdom?
I have heard a heresy that members of the ensemble do not necessarily inherit its properties.
Next time my weak mind deviates from THE WAY, I promise to punish (i.e. enrich, of course) myself with contemplating the depth of your original post.
Cheers!
Well, let me explain. In every intro to the double slit experiment, people talk about a bunch of particles that behave like waves. This is obviously correct. If you take out one particle, and both slits are open, we cannot deduce which slit the particle went through. Nor can we explain what happens with the actual trajectory from source to destination. All we can do is "sum up over all possible trajectories". If a particle would NOT respect the wavelike duality (which you seem to imply) this behaviour would NOT be possible for very obvious reasons. One particle with certain initial conditions will appear somewhere on the detector. Another particle with the exact same initial conditions has a large probability of appearing in another position of the detector. Moreover, the spread in momentum will be INFINTE. Hey, guess what, this story sounds familiar, no ? THAT IS MY POINT.
Also, you are clearly not famliar with the QM concept of self interaction. This applies TO ONE SINGLE PARTICLE, and guess what this stuff means in the context of the double slit exp. YES : Shooting a single photon (or electron) at a wall that contains two slits will result in an interference pattern on the wall (detector plate) beyond the holes.
Like you said yourself, you should not only read without understanding. Check out any intro QM book and read between the lines as well !
True yet irrelevant in this case. One single particle does NOT behave "classically" on the atomic distance scale. What do YOU think " NOT behaving classicaly" might mean. Try to find out this apparent mystery, my dear.
Cheers!
Not necessary, any self respecting intro QM text will do just fine.
Besides, another think for you : destructive interference does NOT mean NO interference...my dear
Good Luck
marlon
I am not sure if we connect. I say that in statistical interpretation the fringes in the double
slit experiment come from the preparation procedure and not from some assumptions
about wavelike nature of the electrons.
In other words: from the fact that the ensemble of electrons is prepered in some
wave function that exhibit fringes under position measurement.
Let me emphasize that the wave function describes an ensemble and not a single member
in that interpretation.
No need for any communication between any two electrons or a to-be-send electron and the detector.
If this doesn't help, could you formulate a specific question?
Cheers!
Cheers!
I presume that in double slit experiments, the electrons can be controlled in such a way that they hit the screen one by one with a considerable time delay. Even then, we are told, the wave pattern builds up. I do not see how you could get such result by preparing the source in some special way unless you assume that there is some physical wave guiding the particle or so. To phrase it correctly, what is the dynamics at the single particle level you have in mind to get the outcome of the double slit experiment.
WRONG. You keep telling me that in some cases the wavelike behaviour of particles cannot be seen from the double slit experiment. Even in the case on destructive interference, there is wavelike behaviour because interference IS BY DEFINITION a wavelike property. You are using the terminology of waves to say, hey in some cases the duality is not clear. Can't you see the contradicitio in terminis, my dear ?
WRONG AGAIN !
Look at the intensity profile of the double slit diffraction. One peak occurs in between the openings etc etc. Such behaviour CANNOT be explained when the particles are "only particle like". This violates the laws of physics. Again, you are forgetting the concept of self interaction here.
marlon
What would you say about Bohmian trajectories, my guru. Particles there do not behave like waves at all and still give correct predictions as to the fringes. Does this Bohm's speculation
have bad karma? What invalidates the interpretation? Why is it impossible?
marlon said:
Moreover, the spread in momentum will be INFINTE. THAT IS MY POINT.
Spread of what in momentum?
You do not surprise me with your knowledge of other branches of physics. But still
your revelations would be better understood if you had given a reason behind them.
How do you know the behavior of a single particle? Does it behave classically on 1 meter scale? One kilometer? Is there any theory in your textbooks of single quantum particles?
Why go after second-hand truths, if the guru is in the mood for explanations?
Cheers!
The guy is talking about the initial wavelike properties that need to be respected for destructive interference to occur (no interference pattern on the detector). A necessary condition for acquiring a interference is determined by the difference in pathlength between two paths that light can take to reach a zone of constructive interference on the viewing screen. This difference must be the wavelength of the light that is used, or a multiple of this wavelength. Newton rings learn us that light does not have to be coherent to produce interference patterns but such patterns are very clear when monochromatic or near-monochromatic light is used. Laser light gives the best (most visible) interference pattern.
He concludes from that that particles do not behave like waves in that case but that is WRONG since all kinds of interference are wave like behaviour, obviously.
marlon
marlon
Yes, that is why I asked him about the single particle dynamics. You know that I would not say that particles behave like (or are sometimes) waves but that the wavelike property is due to a self interaction effect (actually, you could make a (classical) particle theory of waves, but that's rather difficult to control mathematically). But clearly, something wavelike needs to be present at the single particle level; or you could think about a random walk with complex amplitudes with ``ket's'' and ``bra's'' and define a particle event as the merging of a ket and bra, then you give up the notion of a fundamental particle which exists all the time but this leads to other kinds of undesirata.
O.K. Now I get it.
I have no idea, what is the dynamics of a single particle. It could be bohmian trajectories
or another non-local hidden variables speculation. The theory of single particles
is not available so far.
However, in the statistical interpretation as formulated by Ballentine in Rev.Mod. Phys. 42, 358 (1970), one can read where the followers place the origin of the interference fringes.
Instead of blaming single objects of behaving like waves it is pointed out that the preparation
procedure will suffice.
Cheers!
Don't bring in other topics. Let's stick to what we are talking about : the double slit experiment and how it proves the wavelike nature of particles. Particles, in QM, ALWAYS exhibit wavelike properties : THAT IS THE ENTIRE POINT OF THE DUALITY. This duality does NOT give us an "either wave or either particle like" picture.
LOL. Don't you know what momentum is ?
HINT : momentum of a particle + uncertainty principle, my dear believer
Self interaction IS an essential part of QM.
Are you being serious here ? When did i ever claim we knew the exact boundary between classical physics and QM ? There is NO such boundary. We are ONLY talking about what actually happens at the atomic scale where basic QM principles like the p/w duality, superposition or the HUP manifest themselves.
But to be clear, are you saying that a particle's self interaction does not exist ?
Cheers!
That's not good policy to be doing since. Take THAT as lesson nr 1 from your guru.
marlon
Careful said:
Yes, that is why I asked him about the single particle dynamics. You know that I would not say that particles behave like (or are sometimes) waves but that the wavelilke property is due to a self interaction effect (actually, you could make a (classical) particle theory of waves, but that's rather difficult to control mathematically).
Ok got it.
But i just want to be clear here : the particle/wave duality does NOT say that particles are waves or something like that. this duality just states that at the atomic scale, particles exhibit wavelike behaviour like in the double slit experiment. This ALWAYS happens for each kind of particle like electrons photons, etc etc. Wavelike behaviour is a general term that denotes all the types of interference, diffraction, etc etc...
We need this duality because we look at QM through "classical eyes". I mean, we need this duality because we were first familiar with concepts like particles and waves. Should we look at QM through QM glasses, we would never make a distinction between a particle and a wave. The duality would just be a physical behaviour inherent to our QM world. You see my point ?
Now, onto the next discussion :wink:
greets
marlon
Actually, it was for Carful. Anyway, where have you seen a destructive interference of one particle?
marlon said:
WRONG AGAIN !
You keep writing ONLY, EVERY, CANNOT without any argument.
Is there any noexistence theorem for the interference explanation if one skips
the wavelike behavior of particles? Again, what is wrong with the counter example involving Bohmian trajectories?
I still hope for something beyond your statement WRONG. Do you have less guru and more
scientific justifications as well?
Cheers!
marlon said:
Ok got it.
Yes, yes we know this to be true (dont worry).
Well, that is why the logical step would be to try to formulate either a wave theory of particles or a particle theory of waves or something entirely new (like this ket and bra random walk) which captures both. The first was tried by Barut and others with partial succes, I for instance am digging in getting a decent formulation for the second (but it is hard), the last alternative is always cool.
Your point is merely the standard Copenhagen view, which brings you into trouble with relativity and realism. I think a solution to the wave particle duality problem is still of considerable importance although not that flashy to work on.
If you read again our discussion you might notice that I have just given you an explanation
of the fringes without assuming the wavelike nature of particles.
Yeah, I heard something. But more interested in the momentum of what ("of what" is the key here) has INFINITE spread.
So you keep telling me. But again without any justification.
You claimed that "One single particle does NOT behave classically on the atomic distance
scale". I ask you if there is any scale where the particle behaves classically.
And more, what gives you the basis to make claims regarding the behavior of single
quantum objects?
Does it? What exactly do I need it for? Is this one of the postulates of QM?
Or is it derivable from QM?
WRONG AGAIN !
BTW, do you know what the statistical interpretation of QM is? From the quote above one
can unjustly deduce that some more reading for guru is in order.
Ballentine's paper "The statistical interpretation of QM" (1970) would be a good start.
Preferably, before any further discussion on the subject.
You can do it!
Cheers!
zbyszek, could you recommend more readings of statistical interpretation of QM besides Bellentine's review?
Thanks!
Thanks!
There is Einstein's "Reply to criticism" available on-line.
The book "Quantum Theory: Concepts and Methods" by Asher Peres assumes statistical
interpretation and has large parts devoted to hidden variables.
I heard good things about Ballentine's textbook "Quantum Mechanics: Modern developement"
but don't have access to it yet.
Cheers!
Bohm's pilot wave theory should also be a good candidate to consider.
Could one connect both Bohm's theory and statistical interpretation together?
Bohm already did it. The initial conditions for Bohmian trajectories are drawn
from a probability density i.e. a wave function modulus squared. Thus, the wave function
is associated with an ensemble rather than with a single particle.
Cheers!
Not quite!
In the Bohmian approach, the wave function has a double role. It is associated with an ensemble just as you said, but it also determines the trajectory of a single particle. You may, of course, argue that these trajectories are useless, meaningless, or whatever you want, but you cannot say that, in this particular interpretation, the wave function is not associated with properties of single particles.
  • #31
Cheers!
Wow. I never knew that initial preparation is responsible for double-slit electron diffraction. Gee, I always thought that the restriction of the wavefront was the major cause. So, I wonder how electron microscope manufactures guarantee that their electrons are properly prepared?
Perhaps you would be so kind as to enlighten us on what constitutes proper preparation for electron diffraction?
Also, would you be so kind as to show us how to compute the correlation between electrons in a XX-slit experiment of any kind. Usually we assume that the incident electrons are independent, hence they cannot be correlated . (There is one correlating factor, the Pauli Exclusion Principle, but, as I'm sure you know, single particle matrix elements of fermions don't create any noticable corrrelations. Further, bosonic objects will also show diffraction patterns.) Most would agree that there is a correlation pattern at the detecting screen. You, unless I'm mistaken, suggest that the correlation is in the preparation. Doe this mean that with proper preparation, we can get electron diffraction without a screen?
I hope that you can enlighten us on these matters -- then I'll be able to revise my thesis on electron diffraction from protons --, which I always thought was right. Also, you might clue us in on the proper way to deal with many issue in solid state physics, conducting, superconducting, and non-conducting materials for example, or in dealing with cascades of cosmic rays.
Also, re probability and ensembles -- see a few books on probablity theory, preferably those that deal with measure theoretic approaches and events, and, perhaps look at ergodic theory-- to understand why you are less than correct on this issue.
But, no matter, in spite of your doubts, QM and particle diffraction are alive and well, conform to the strictures of QM, and make this very forum possible.
Regards,
Reilly Atkinson
  • #32
Demystifier said:
Not quite!
Hi Demystifier,
The wave function is as much associated with a single particle as an external potential.
It is like saying that periodic potential of a crystall lattice is a property of an electron
in a Bloch band.
Thank you for the contribution!
Cheers!
  • #33
Regards!
Before I start the enlighment tell me what exactly you are questioning.
Is it:
1. statistical interpretation of QM you are not comfortable with or,
2. is it my understanding of the interpretation that is not sufficient?
I cannot help on 1. but will be happy to improve in case of 2.
Same regards!
  • #34
Marlon:” We need duality because we look at QM through "classical eyes".
Perfect explanation.
Careful:” Your point is merely the standard Copenhagen view, which brings you into trouble with relativity and reality.”
zbyszek:” Ballentine's paper "The statistical interpretation of QM" (1970) would be a good start. Preferably, before any further discussion on the subject.”
L.E. Ballentine (p.359): “The primitive concepts are those of state and of observable. … This implies that any state operator may be diagonalized in terms of its eigenvalues and eigenvectors.”
This is like to say that the proton is the elementary particle which is the QM ground state of the three bounded point-like fermions called quarks.
L.E. Ballentine presentation is obscure, tedious, didactic, eclectic and old turkey style. In addition, it is simply wrong, since the writer reject the experimental evidence.
Quantum River:” could you recommend more readings of statistical interpretation of QM besides Bellentine's review?”
The clear presentation and discussion of the problem is given by E.P.Wigner in the paper “The problem of Measurement” (AJP,31,6 (1963)).
For me the key statement of the paper is:
“The misgivings, which are surely shared by many others who adhere to the orthodox view, stem from a suspision that one cannot arrive at valid epistemological conclusions without a careful analysis of the process of the acquisition of knowledge. … We are facing here the perennial question whether we physicists do not go beyond our competence when searching for philosophical truth.”
Recent investigations performed by A. Zeilinger and others moved that issues from the area of philosophy to the standard experimental and theoretical treatment (see for example quant-ph/0212084) used in the physics. The theory of measurement must be accompanied by the description of the process of the acquisition of knowledge. The density matrix and the projection operators seems to provide suitable dynamical variables. Whether the Born interpretation is necessary for the description we will see in the future.
  • #35
I meant realism. :redface:
  • #36
So you are the man of your word. You have read it.
Could you explain in more detail what experimental evidence has been rejected
by Ballentine, please?
Cheers!
  • #37
Zbyszek:” Could you explain in more detail what experimental evidence has been rejected by Ballentine, please?”
The “collapse of the wave function” . We already discussed that in the “wave packet description” session.
The “collapse of the wave function” is not a postulate and it is not interpretation dependent. The collapse is universally valid firmly established experimental result connected with the transition from Quantum world to Classical world (E. Schrödinger cat). The collapse is a key problem of the measurement theory and therefore also is called “The Measurement Problem”. The theoretical description of the natural phenomena is groundless without consistent and adequate measurement theory. There are and always will be people that claim that a quantum world is a classical world or a classical world is a quantum world, that the measurement problem do not exist, AB phenomenon do not exist,quarks do not exist, etc. These are the people that have no problems in their world. God bless them. But it is not interesting world.
  • #38
The world in which the experiments you consider to be conclusive are accepted as such must be very poor minded indeed.
  • #39
Is the collapse also required in the interpretation where the wave function is not associated
with any single object but only with ensembles?
I might have some insides, not discussed in QM textbooks yet, as to the quantum to classical transition, and to the Schrodinger cat problem in particular.
For example, the lack of observed superpositions of macroscopic objects can be derived from a structure of the many-body wave functions of those objects.
If you mock up the measurement process by sampling (can be approximate) of the many-body probability density (the wave function modulus squared) you will find that the
density itself prevents macroscopic superpositions from happening in the results of measurements.
No reduction of the wave function required.
Cheers!
zbyszek
  • #40
Careful:” The world in which the experiments you consider to be conclusive are accepted as such must be very poor minded indeed.”
But I am happy to be there. In addition, I have plenty of tools in my restaurant.
  • #41
Zbyszek:” Is the collapse also required in the interpretation where the wave function is not associated with any single object but only with ensembles?”
The theory should explain the results of experiments. That all.
In the wave-packet description session you stated that the Born interpretation is exception, may be more than interpretation. L.E. Ballentine reduced it to just another interpretation. As I stated above, I made my mind. You helped me to do that. I am grateful to you for that. I do not intent to convince anybody. I try to understand.
  • #42
Cheers!
Then you should get it really quickly. It' simply splendid. By far, the best book in the field. :approve:
Daniel.
  • #43
It is a postulate, it's necessary to merge it with the other axioms, as Ballentine shows. Oh, and yes, it's probably difficult to follow his 1970 article, simply because it's difficult to follow any article of that kind, including Wigner's that you quoted.
Daniel.
  • #44
Anonym,
Let me stick to this sentence of yours.
Our brains trick us into believing things that do not exist and make as blind to plain evidence
residing just in front of us. I am not patronizing you. The same happens to me way too often.
One way to fight that is to employ different parts of our brains when analysing
a problem.
How is it done?
In the case of reading a paper, that you presume to be wrong(right), you try to remember
that your mind is trying to trick you. During the analysis of the paper try to find evidence that
the paper is correct(wrong). The oposite to the presumption.
In my case, I contemplate almost every sentence of the paper and try to dig out its meaning
in relation to preceeding sentences in a way that would contradict my presumptions.
It takes time but often pays off with understanding.
Give Ballentine a chance. If you are really after the understanding, analyse the first 15 pages
of the review temporarilly assuming that Ballentine is right and your brain plays with you.
After that you will either find better evidence supporting your reservations or annihilating them.
As a side remark, such an exercise would help you deal with symptoms of Alzheimer's desease if you are unlucky to suffer from it in the future.
Cheers!
  • #45
LOL
That makes TWO of us. This is the very point i was objecting against but this guy just doesn't want to hear me out.
Don't bother :smile: i have asked a similar question before.
Exactly, also a question i have asked to him. Yet no answer.
greets
marlon
  • #46
Hmm, I'm pretty confused by zbyszek's comments. I've tried to make sense of them from zbyszek's point of view. I think what s/he means by the preparation of electrons etc. is that, for example, for an intereference pattern to be observed, we need coherence etc.
I'm not sure though; is this really what zbyszek means?
  • #47
Try to read the 8-th and 9-th chapters of Ballentine's QM book or the article in discussion to get the idea behind his assertions.
Daniel.
  • #48
He means that for an interference pattern to be observed all electrons have to follow the same wave function. In particular, this means the coherence etc.
In order to satisfy this requirement, the electrons have to be carefully prepared. They cannot
be cast into the experimental setup regardless of their energies and momenta.
In the statistical interpretation of QM the preparation procedure of an ensamble of electrons is synonymous to the wave function of the ensemble.
Cheers!
  • #49
marlon said:
LOL
greets
marlon
Could not agree more. Somehow, all I see is a future in this thread that is full of words, but little concrete substance. That is, don't hold your breath on getting answers to our questions.
Regards,
Reilly
  • #50
Zbyszek:” Originally Posted by Anonym
Let me stick to this sentence of yours.”
Careful:”The world in which the experiments you consider to be conclusive are accepted as such must be very poor minded indeed.”
I do not want to go too far beyond my competence. For me understanding means translation into the suitable mathematical language ( here I see three and Born approach is not relevant at least at the beginning). Now a question is how the difference between the information and the information rate is defined. As Careful said it is “very poor minded indeed.”
