Statistical Mechanics: Calculating Pressure on a 3D Box Wall
The discussion focuses on calculating the pressure exerted by a particle confined in a cubic box using statistical mechanics. The pressure on a wall is derived from the force exerted by the particle, which is related to the change in energy with respect to the box's dimensions. Participants seek guidance on how to relate changes in box dimensions to pressure and how to utilize the symmetry of quantum numbers to simplify calculations. It is noted that the average values of quantum numbers can be treated equally due to symmetry, allowing for a straightforward expression of mean pressure in terms of mean energy and box volume. The conversation emphasizes the need for clarity in deriving these relationships without seeking a final answer.
vladittude0583
Consider a particle confined within a box in the shape of a cube of edges Lx=Ly=Lz. The possible energy levels of this particle are then given by the quantized energy for a particle in a 3D box.
Calculate explicitly the force per unit area (or pressure) on this wall. By averaging over all possible states, find an expression for the mean pressure on this wall. (Exploit the property that the average values of the quantum numbers must all be equal by symmetry). Show that this mean pressure can be very simply expressed in terms of the mean energy of the particle and the volume of the box.
In part (a), it was said that the particle exerts a force on a wall perpendicular to the x-axis such that Fx= - dE/dLx (these are partial derivatives).
I don't want the final answer, however, I just need guidance on how to get there
1) This is through a quasistatic process such that dW=(mean pressurve)*dV
2) What does it mean when "exploit the property that the average values of the quantum numbers are all equa by symmetry?"
3) I know that the length along the x-axis changing by an amount dLx whereas the area of the wall is A=LyLz=constant. How do I related these values together?
4) I understand how to solve it using Kinetic Theory of Gases, however, my professr prefers using the method of pressure, etc.
5) Just some guidance is greatly appreciated. Thanks!
Regarding your question 3, it could mean that you will be able to determine a quantity that is given by the sum of the three average values, but not the average values individually. In that case you could exploit a symmetry to say that each of the average values would be 1/3 of the total.
Torquil
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
