How Do Gases Reach Equilibrium in Partitioned Containers?
FourierX
A box is separated by a partition which divides its volume in the ratio 3:1. The larger portion of the box contains 1000 molecules of Neon gas, the smaller one contains 100 molecules of He gas. A small hole is made in the partition, and one waits until equilibrium is obtained.
Find the mean number of molecules of each type on either side of the partition.
Basic statistical and probability concept.
At equilibrium, maintaining the volume ratio
the mean number of molecules of Ne in bigger partition = 750
the mean number of molecules of Ne in smaller partition = 250
the mean number of molecules of He in bigger partition = 25
the mean number of molecules of He in smaller partition = 75
That is what i ended up with. Any comments or suggestions will be greatly appreciated.
Gilchrist
hi gilchrist
Ne makes sense, but I wonder why 75% of HE is in the small box, I would have thought everything would be distributed evenly at equilibirum...
actually, you are right ! I typed the wrong information. My bad.
Thank you :)
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
