Steady State Thermal Analysis - Simulation
In simulating a hot forging process in LS-Dyna, achieving steady-state temperature for the tool is challenging due to continuously increasing temperatures at the contact point. Key factors for steady-state thermal analysis include proper thermal boundary conditions, such as convection, and ensuring that the tool and workpiece are correctly modeled. The tool's material properties and heat transfer conductance at the contact interface are crucial for accurate results. Using deformable elements with temperature degrees of freedom instead of rigid bodies can allow for temperature changes during the simulation. After addressing the issue of temperature boundary conditions not being in contact with the tool, the model was corrected to potentially achieve steady-state.
shravanaumesh
TL;DR Summary
A tool contacts new hot workpiece every 10 sec. What are the factors needed in a simulation to check when the tool reaches steady state temperature?
I am simulating a hot forging process in LS-Dyna. A tool is contacting a hot workpiece for 2 sec every 10 sec (--0 sec--contact--2 sec--no contact---10 sec--) in a factory. Since this is a continuous process, the tool should, at some point, attain steady temperature. I have tried to recreate it in LS-Dyna but I get a continuously increasing curve of temperature at the point of contact at end of 10 sec every time. So I want to clarify my basic understanding of this process.
What factors are needed to be considered for steady-state thermal analysis?
Is having only tool and workpiece resulting in only increase of the tool temperature? OR Will adding the other components of the machine help the tool achieve steady-state?
Make sure that thermal boundary conditions (such as convection) are properly defined. Maybe it will take some time for the tool to reach constant temperature so you may have to increase the simulation time.
Likes shravanaumesh
Thank you for the reply.
My thermal boundary is limited to the tool having temperature of 20°C and the workpiece with 1050°C. The tool material is defined by MAT_RIGID with THERMAL_ISOTROPIC property. There is Heat Transfer Conductance defined at tool-workpiece contact. Is there any other property that is necessary that I have missed?
I have a reference of the same simulation reaching steady state in 19 cycles so I am trying to validate my model with it.
I don’t use LS-Dyna but it’s probably the same as in other software. When you use rigid bodies defined as isothermal then they have uniform temperature all the time. For this analysis I would use deformable elements with temperature DOFs and apply these temperatures as initial ones so that they can change during the analysis (temperatures prescribed as boundary conditions are kept throughout the simulation).
I checked my model and you are right. The nodes with temperature boundary conditions were not in contact with the tool. Hence there was continuous increase in the tool. I have rectified the problem.
Thank you for your help!
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
