Steel Soap bars: magnetic core, solid?
The discussion centers on the functionality and design of stainless steel soap bars, particularly regarding their hollow versus solid construction and the potential effects of incorporating a magnetic core. Users express curiosity about whether a solid core or a magnetic-friendly metal would enhance the bar's effectiveness in utilizing charged ions. One participant aims to create a levitating soap bar that avoids contact with surfaces to maintain cleanliness, highlighting the challenges of achieving stable magnetic levitation without electromagnets.
  • Understanding of magnetic fields and their properties
  • Knowledge of charged ions and their behavior
  • Familiarity with magnetic levitation principles
  • Basic concepts of material science related to metals
  • Research the properties of different metals in relation to magnetic fields
  • Learn about the principles of magnetic levitation and its applications
  • Investigate the chemistry of charged ions and their interactions
  • Explore design techniques for creating stable magnetic levitation systems
Inventors, product designers, and anyone interested in the intersection of materials science and innovative cleaning solutions.
rovot
I bought a Stainless Steel soap bar and it works, it just does. It was from China and hollow inside and I would like to know if that's either a cost cutting measure or how the bar works? What would happen if it were solid?
Another thing would be if it had a magnetic core, or made from a metal that reacted to magnets a lot more so than Stainless Steel already is. How would this affect the perceived working of the device please?
I bet on cheapo cost cutting
Well it all works on positive and negative charged ions and I was wondering if a hollow/solid core would change that, even more so if it were a different metal in the core i.e. magnetic friendly or how the ions might change if coming into contact with a magnetic field?
Actually, I have seen some of the bars that are not hollow. But they cost more.
Basically, I would like to create a version of bar myself in which it has a core that can react to a magnetic field in order to levitate it above a surface, that way it should remain cleaner as it will not come into contact with the germs.
So I wanted to know if the magnetic field, a different metal and a solid core would have an affect on the working of the bar itself?
What's a soap bar in this context? Especially stainless steel ones.
The magnetic field wouldn't make a bit of difference.
Levitating and object using solely magnetic fields is inherently unstable and requires electromagnets to work properly if my memory is correct.
It can be done with pens:
Read the description:
The pen is actually being pushed to the right, but the motion to the right is being prevented by the plastic barrier.
That's what I mean when I say that magnetic levitation is unstable. You either need a physical barrier to prevent the object from moving, or you need to constantly change the magnetic field using electromagnets.
I could handle a little terminator, if tastefully done, but to get it off the ground is my main aim.
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 43 ·
  • · Replies 21 ·
