Solving Reflection Coefficient for Step Potential: Why B ≠ 0?
Thyestean
I'm working through a step potential and I am confused as to why one of the coefficients doesn't go to zero.
V(x) = 0 when x < 0;
V(x) = V_not when x > 0;
a. Calculate reflection coefficient when E < V_not
I can solve the reflection part, it is a step towards it that i am confused about.
Now i know the solutions solve to:
Aexp(ikx)+Bexp(-ikx) where k= sqrt(2mE)/hbar when x<0
Cexp(lx) where l=sqrt(-2m(E-V_not)/hbar when x>0
So my question is why doesn't B=0? Because when x->-infinity it goes to infinity so B has to be 0. The only reason i can think it wouldn't is because of tunneling. If this is the case how do I spot this. Is it only relevant in step potentials?
e-ikx is oscillatory. It doesn't blow up as x goes to -∞.
Ah thank you. Now that brings up another question for the same problem but now E>Vo.
The wave equations go to:
Aexp(ikx) + Bexp(-ikx) when x < 0. k=sqrt(2mE)/hbar
Cexp(ilx) + Dexp(-ilx) when x > 0. l=sqrt(2m(E-Vo))/hbar
Now in this case why does D=0.
It's a boundary condition essentially. The idea here is you have an incident wave coming from the left. That corresponds to the A term. When it hits the potential step, you get a reflection, the B term, and a transmitted wave, the C term. The D term would correspond to a wave traveling to the right from x=+∞. You could certainly solve a problem with D not equal to 0, but it would be a different physical situation than the one you're interested in.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
