What is the problem with the Stern Gerlach J=1 exercise?
In summary, Helium atoms in the excited state 23S1 come out from a box at v=2000 m/s and pass trough an Stern & Gerlach apparatus with dB/dz=25 T/m and length L=0.30m. Atoms spends 1 hour in the box and the average-time for decay is 8000s. The questions are: 1) evaluate (number of atoms deflected with Mj=1) / (total number of atoms came out from the box) 2) evaluate the angular deflection of the component Mj=1.
folgorant
29
Hello! i have a trouble with an exercise of a course of structure of matter.
the questions are:
So, the part 2 is very simple:
i know that the state has S=1, L=0, J=1 and using F = [tex]\mu[/tex]z * dB/dz I found alpha=0.30.
But I can't understand part 1:
8000s>1hours so every atom producted come out form the box and don't decay to the ground state??
then, don't the 3 components Mj= 1, 0, -1 should have the same probability 33.3% ?
Or I should use statistical mechanics and evaluate the probability of that state in function of temperature and energy?
please help me to understand, thank you!
This seems irrelevant, but with an exponential decay process some atoms will have decayed, some will take longer than 8000 s to decay. 8000 s is the average decay time.
Sounds right to me. So the answer is _____ ?
the answer is: 21.25%
Okay, my mistake. After reading the original post more carefully, we need to divide the J=1 atoms by the TOTAL number of atoms. So the decay part of the problem is relevant after all.
So, you first need to figure out what percentage of the atoms are remaining in the 23S1 state. It's an exponential decay type of problem.
yes...
if N is total number of atoms;
y=1/8000 is the decay rate (number of decay/sec)
t= 1 hours = 3600sec is the period atoms be in the box
so: 1/8000 * 3600 * N = 0.45N i.e. the percentage of atoms remaining in excited state is 55%.
after this..i should evaluate the probably P(Mj=1)=[exp(-beta*E(Mj=1 state)]/[exp(-beta*E(Mj=1 state) + exp(-beta*E(Mj=0 state) + exp(-beta*E(Mj=-1 state)]...
where:
beta=1/(kT)
k= Boltzmann constant
T obtained from: 3/2 k T = 1/2 m v^2
but i should know the value of magnetic field to evaluate the energy states! instead i know only its gradient!
folgorant said:
yes...
No, the population of excited atoms is an exponentially decaying function. You are using a linear function, which is incorrect.
Using your formula, how many ground-state atoms are there after 8800 seconds? Look at the result you get ... do you see the problem?
where:
beta=1/(kT)
Usually in this type of apparatus, B=0 immediately after leaving the oven. It is only after they have traveled some distance away from the oven exit that they enter the magnetic field.
thank you very much Redbelly98...now it's okay!
i've used: N=N(0)exp(-t/T) and then dividing for 3 the result is correct!
thanks...
You're welcome!
1. What is the Stern Gerlach J=1 problem?
The Stern Gerlach J=1 problem refers to a quantum mechanical experiment where a beam of particles with a specific angular momentum (J=1) is passed through an inhomogeneous magnetic field. This results in the particles splitting into three distinct beams, rather than the expected two beams.
2. Why is the Stern Gerlach J=1 problem important?
The Stern Gerlach J=1 problem is important because it highlights the need for a more comprehensive understanding of quantum mechanics. It challenges our current understanding of how particles behave in magnetic fields and has led to further research and development in this area.
3. What are some proposed solutions to the Stern Gerlach J=1 problem?
Some proposed solutions to the Stern Gerlach J=1 problem include the use of higher order magnetic fields, such as quadrupole fields, to better control the beam splitting. Another solution is to use more precise and sensitive detectors to measure the particle's spin.
4. How does the Stern Gerlach J=1 problem relate to other quantum mechanical problems?
The Stern Gerlach J=1 problem is related to other quantum mechanical problems, such as the double-slit experiment and the uncertainty principle. It highlights the counterintuitive behavior of particles at the quantum level and the limitations of our current understanding of quantum mechanics.
5. What are the potential implications of solving the Stern Gerlach J=1 problem?
If the Stern Gerlach J=1 problem is solved, it could lead to a better understanding of quantum mechanics and potentially open up new possibilities for applications in technology and science. It could also help bridge the gap between classical and quantum mechanics and lead to further advancements in these fields.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
