Solving Potassium Dichromate Homework Problem
  • Thread starter Thread starter Quantum Mind
    Stoichiometry
To determine the grams of potassium dichromate (K2Cr2O7) in a 1 liter N/10 solution, the calculation starts with the formula gram eq = NV, yielding 0.1 equivalents. The valence factor is considered as 14 due to the acidic medium, leading to the equation g = gram eq * mol wt / valence factor. This results in 2.1 grams, but further calculations with the equivalent weight of 49 grams per equivalent suggest that the correct answer is 4.9 grams. The final conclusion confirms that 4.9 grams is indeed the correct amount of potassium dichromate in the solution.
Quantum Mind
How many grams of potassium di chromate (K2Cr2O7) are present in 1 lit of its N/10 solution in acid medium?
gram eq = NV = g/E = xg/M
gram eq = NV = 0.1 * 1 = 0.1
g = gram eq * mol wt / valence factor (The valence factor I have taken as 14 because there are 7 oxygen atoms in potassium dichromate, which means in acidic solution there would be 14 H+ atoms)
0.1 * 294 / 14 = 2.1
How to proceed beyond this? The answer is one of the four:4.9, 49, 0.49, 3.9.
OK, got it.
gram eq = no. of grams / Equ. wt
E = mol. wt/val factor = 294.2 / 6 = 49
g.e * E = 4.9.
Is this the answer?
Looks OK to me.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
