Stopping discharging a battery during charging
  • Thread starter Thread starter adilsyyed
    Battery Charging
To manage a lead acid battery-powered light during frequent power outages, a relay can be used to automatically turn off the light when charging begins. This setup requires a "break-before-make" relay to ensure the light disconnects from the battery when the charger is engaged. The relay should be powered by the wall outlet, allowing it to switch between configurations for charging and discharging. Users are encouraged to research relays further to understand their operation better. This solution provides a practical way to maintain light during outages while preventing battery discharge during charging.
adilsyyed
I am from a country where power outage is very common.
I have a light source which is run by a lead acid battery. At night, I want to keep this light ON during power outage and when the electricity is back on, the charging circuit engages and the lights should turn off itself.
I am guessing an arrangement would be needed so that when the charging starts, with it somehow, a circuit should sense it and open/dis-engage the discharging circuit.
Simple Version:
I want to plug the charger in the battery, during power outage the light will be ON and with power on (when the charger starts charging the battery), the light turns OFF.
Simple Version:
I would use a relay powered from the wall power. You can connect your light and charging circuit to different parts of the relay to give the two different configurations.
ummm... That would be a nice way to do it.
Be sure to use a "break-before-make" type of relay. :smile:
If only I was expert in electronics.
But thanks for the head start, that's how we learn. I am going to read more about the relay you proposed.
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
