Strange radioactivity question.
EasyStyle4747
well, this is a strange question that i have to do a presentation on. I thought it would be easy but i can't find any information after looking through 2 major physics books and searching online. I even asked a tutor about this and still couldn't get any equations i could use. Plz don't bash me if this is the wrong forum. Just direct me to the right one then. This is the problem:
__________________________________
Radioactive Emission Ranges: For a 35 becquerel (Bq) source of alpha radiation, calculate the rate of particles arriving at a 5.0x10^-4m^2 detector located 20.0 cm, 50.0 cm, 100.0cm, and 130 cm from the source. Repeat the calculations for the same detector at the same positions for a 48 Bq source, a 125 Bq source, and a 1753 Bq source.
Tabulate and graph your results on a detection rate (Bq) versus distance (cm) graph, with source activity(Bq) as an extra parameter.
______________________________________
Just need an equation or equations to solve this. You don't have to solve it. I am not tryin to cheat, i just need to know where to even start with this thing. I can't find any equation that includes distance along with detection rate and area. Both books don't have anything. Am i suppose to use several equations together or wat? If anyone has any idea how this is done, please help me.
You have, for the 35 Bq source, 35 disintegrations per second. You have to assume that these are emitted isotropically, meaning that they are emitted uniformly in all directions over a solid angle of 4pi.
What you need to do is figure out, at a particular radius (detector location), what is the ratio of the area of your detector to the total spherical area. The ratio will tell you what fraction of the particles will enter your detector per second, giving you the detection rate. Do this for all the radius, and repeat for the different decay rate.
Zz.
hmm, so is this what u mean: (rate of bqs) * A / 4(PIE)r^2
And why is it the spherical area and not the volume?
The question is, why should it be the volume? What logical justification calls for that based on the question given?
How much of the particles that enters the detector depends not on any volume, but rather the area of the detector to catch those particles. The closer the detector is to the source, the large the ratio of the area that it is catching.
I suppose if one is a masochist, one can find the volume of the solid cone with the surface of the detector as the base, and then find the ratio of that with respect to the total spherical volume, but why bother with that much work? But in doing that, you have to assume the shape of the detector's surface area, which you are not given... Again, way too much unnecessary work.
Zz.
ok, i think i know what u mean. So i assume there's nothing wrong with the equation i have then right?
there is nothing wrong with that equation. The 35 dps have to be uniformly(evenly) distributed over a sphere whose origin is the 35 dps source. This means that you will detect an amount of dps equal to the percentage of the sphere you are monitoring.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
