How Do You Calculate the Streamlines and Pathlines of an Incompressible Fluid?
  • MHB
  • Thread starter mathmari
In summary, we found the equations for the streamlines and pathlines of a velocity field representing the flow of an incompressible fluid. We also calculated the constant $c$ in terms of the given constants $a$ and $b$ to satisfy the incompressibility condition. And we can plot the streamlines and find the pathlines of specific elements using the equations we derived.
mathmari
MHB
5,049
Hey! :eek:
Construct and draw the streamlines of the velocity field $u=az-bt, v=\frac{b}{4}z-cy, w=2(a-1)$. Calculate $c$ (as a function of the constants $a$, $b$) such that the flow field $\overrightarrow{u}=(u, v, w)$ represents the flow of an incompressible fluid. Find also the pathlines of the element of the fluid that at the time $t=0$ it is at the position $(x_0, y_0, z_0)$.
I have done the following:
$$\frac{dx}{u}=\frac{dy}{v}=\frac{dz}{w}$$
$$\frac{dx}{az-bt}=\frac{dy}{\frac{b}{4}z-cy}=\frac{dz}{2(a-1)}$$
$$\frac{dx}{az-bt}=\frac{dz}{2(a-1)} \Rightarrow 2(a-1)dx=(az-bt)dz \Rightarrow 2(a-1)x=a\frac{z^2}{2}-btz+d$$
$$\frac{dx}{az-bt}=\frac{dy}{\frac{b}{4}z-cy} \Rightarrow \frac{x}{az-bt}=-\frac{\ln \left (\frac{b}{4}z-cy\right )}{c}+m$$
Is this correct so far?? (Wondering)
So, which are the streamlines?? (Wondering)
From the fact that the fluid is incompressible we have the following:
$$div \overrightarrow{u}=0 \Rightarrow (u, v, w)=(0, 0, 0) \\ \Rightarrow az-bt=0 \text{ and } \frac{b}{4}z-cy=0 \text{ and } 2(a-1)=0 \\ \Rightarrow az=bt \text{ and } c=\frac{bz}{4y} \text{ and } a=1$$
Is this correct?? (Wondering)
To find the pathlines we do the following:
  • $$\frac{dx(t)}{dt}=u \Rightarrow \frac{dx(t)}{dt}=az-bt \Rightarrow \frac{dx(t)}{dt}=a(2(a-1)+z_0)-bt \\ \Rightarrow \frac{dx(t)}{dt}=2a(a-1)+az_0-bt \Rightarrow x(t)=(2a(a-1)+az_0)t-\frac{b}{2}t^2+x_0 $$
  • $$ \frac{dy(t)}{dt}=v \Rightarrow \frac{dy(t)}{dt}=\frac{b}{4}z-cy(t) \Rightarrow \frac{dy(t)}{dt}=\frac{b}{4}(2a(a-1)t+z_0)-cy(t) \\ \Rightarrow \frac{dy(t)}{dt}+cy(t)=\frac{b}{2}a(a-1)t+\frac{bz_0}{4} \\ \Rightarrow y(t)=\frac{(y_0c^2-c\frac{bz_0}{4}+\frac{b}{2}a(a-1))}{c^2}e^{-ct}+\frac{\frac{b}{2}a(a-1)t}{c}+\frac{c\frac{bz_0}{4}-\frac{b}{2}a(a-1)}{c^2}$$
  • $$ \frac{dz(t)}{dt}=w \Rightarrow \frac{dz(t)}{dt}=2(a-1) \Rightarrow z(t)=2(a-1)t+z_0$$
Mathematics news on Phys.org
As for the streamlines, we can plot them by using the equations we found earlier. The streamlines will be curves that satisfy the following equations:
$$2(a-1)x=a\frac{z^2}{2}-btz+d \text{ and } \frac{x}{az-bt}=-\frac{\ln \left (\frac{b}{4}z-cy\right )}{c}+m$$
To simplify the equations, we can set $d=m=0$. Then, the streamlines will have the form:
$$2(a-1)x=a\frac{z^2}{2}-btz$$
and
$$\frac{x}{az-bt}=-\frac{\ln \left (\frac{b}{4}z-cy\right )}{c}$$
We can plot these equations using a graphing software or by hand. The resulting curves will be the streamlines of the velocity field.
As for the pathlines, we have found the equations for $x(t)$, $y(t)$, and $z(t)$ in terms of time. To find the pathline of a specific element at time $t=0$, we simply plug in the initial position $(x_0, y_0, z_0)$ into these equations. The resulting parametric equations will give us the pathline of that element.
What are streamlines and pathlines?
Streamlines and pathlines are two concepts used in fluid dynamics to describe the motion of a fluid. Streamlines refer to imaginary lines that show the direction a fluid would flow at a particular point in time. Pathlines, on the other hand, are the actual paths that individual particles of a fluid take as they move through the system.
What is the difference between streamlines and streaklines?
Streamlines and streaklines are often confused, but they have different meanings. Streamlines show the instantaneous direction of fluid flow, while streaklines show the path that a particle has taken over a period of time. In other words, streaklines are a collection of streamlines that have been recorded over time.
How are streamlines and pathlines useful in fluid mechanics?
Streamlines and pathlines are useful in fluid mechanics because they help us visualize and understand the complex motion of fluids. They can also be used to predict the behavior of fluids in different systems and to analyze the efficiency of fluid flow in engineering applications.
Can streamlines and pathlines intersect?
No, streamlines and pathlines cannot intersect. Streamlines represent the direction of fluid flow at a single point, and therefore, they cannot cross each other. Pathlines, on the other hand, show the actual path of a particle, and they cannot intersect because a particle cannot be in two places at once.
How can streamlines and pathlines be visualized?
Streamlines and pathlines can be visualized using different techniques, such as dye injection, particle tracking, and computational fluid dynamics simulations. These methods allow us to see the flow patterns and understand the behavior of fluids in different systems.
  • General Math
  • Mechanics
