Comparing Stresses and Elongations of Wires with Different Dimensions
  • Thread starter Thread starter BrainMan
    Elongation Stress
The discussion focuses on comparing the stresses and elongations of two wires made from the same metal but differing in dimensions. Wire 1 is four times longer and has twice the diameter of Wire 2. The correct calculation shows that the thinner wire experiences four times the stress of the thicker wire, not eight times as initially calculated. Additionally, the elongation equations were clarified, emphasizing the importance of correctly applying the formulas for stress and elongation.
  • Understanding of stress and strain concepts in materials science
  • Familiarity with the equations for stress (stress = F/A) and elongation (elongation = ΔL/L)
  • Basic knowledge of geometric properties of wires, including diameter and length
  • Ability to perform algebraic manipulations and calculations
  • Review the principles of material mechanics, focusing on stress and strain
  • Explore the effects of wire dimensions on mechanical properties
  • Learn about the relationship between load, area, and stress in different materials
  • Investigate advanced topics in elasticity and deformation in materials
Students studying materials science, engineers working with structural materials, and anyone interested in the mechanical properties of wires and their applications in real-world scenarios.
BrainMan
Two wires are made of the same metal but have different dimensions. Wire 1 is 4 times longer and twice the diameter of wire 2. If they are both under the same load, compare (a) the stresses in the two wires and (b) the elongations of the two wires.
stress = F/A
elongation = ΔL/L
[/B]
For the first part I did
F/A
F/((x/2)^2*3.14)
2F/3.14x^2
F/A
F/((x/4)^2*3.14)
16F/3.14x^2
So it should be that the thinner wire experiences 8 times as much stress as the thicker wire. However the correct answer is that the thinner wire experiences 4 times as much stress.
You forgot to square the 2 in your first equation .
Elongation is change in length. You have written the equation for strain.
Ok I figured it out. Thanks!
