Stress generated by a bending moment
3 replies · 3K views · last reply
Amaelle
Good day all,
I have an issue regarding the theoretical concept regarding the stress generated by the skew bending
in a rectangular cross section for example
Diagram of a rectangular cross section with x and y axes through its centre, corners labelled A (top right) and B (bottom left), and a dash-dot line through the centre at angle φ from the x axis.
the formula used to calculated the stress is
Equation for maximum normal stress under combined axial force and biaxial bending: sigma_zz^max = N/A + (M_x/I_xx)·y − (M_y/I_yy)·x.
while when it is a circular cross section we have the following formula
Handwritten-style text and equations on bending stress in a circular cross section, with a diagram of a circle showing the total moment Mf at angle theta equal to phi to the x-axis and the neutral axis n.a. perpendicular to it.
I really can't understand why we use different formulas in the second case (I couldn't understand the given explanations)
many thanks in advance
  • Equation for maximum normal stress under combined axial force and biaxial bending: sigma_zz^max = N/A + (M_x/I_xx)·y − (M_y/I_yy)·x.
  • Handwritten-style text and equations on bending stress in a circular cross section, with a diagram of a circle showing the total moment Mf at angle theta equal to phi to the x-axis and the neutral axis n.a. perpendicular to it.
  • Diagram of a rectangular cross section with x and y axes through its centre, corners labelled A (top right) and B (bottom left), and a dash-dot line through the centre at angle φ from the x axis.
In the case of the rectangle, there is a natural direction for the coordinate axes. You do not have to use those, but if you choose something else then the calculations of the moments get messy.
For the circle, it is clear that you can choose any pair of orthogonal axes. The moments will be the same. So it is convenient to choose axes that are orthogonal to / parallel to the bending moment. That gives the simpler equation found.
You could, again, choose arbitrary axes and use the same equation as for the rectangle, but numerically the answer will be the same.
Thanks a lot for your answer, but this point still confuses me, could you please point me out a link where i can study more this particular issue?
I do not know any links to recommend. There must be lots out there, but you can search them as easily as I can.
