B Stretching (tearing) of string
  • B
  • Thread starter Thread starter DesertFox
    String
The discussion centers around a formula, F = 2ρdl(d²l/dt²), which is proposed to relate to the maximum stretching force of a string and its properties. Participants debate the validity of the formula, with some asserting it is incorrect due to issues with units and the misapplication of concepts like tensile strength. The argument suggests that stress, rather than force, is what ultimately causes a string to break, and emphasizes the importance of proper references in scientific discourse. There is a strong recommendation for the original poster to seek credible physics resources rather than relying on potentially flawed texts. Overall, the consensus leans towards the formula being invalid and encourages further learning in physics principles.
DesertFox
Hello everbody!
I found the following representation: F = 2ρdl(d²l/dt²)
F - the maximum stretching force (force at which the string tears);
ρ - density;
dl - random differential section of the string;
t - time.
This is some kind of parallel between WAVE and STRING?
I cannot find information in the world biggest search machine, so every single explaining comment will be highly appreciated...
Thank you!
DesertFox said:
Hello everbody!
ρ - density;
t - time.
Thank you!
if this formula is from the same author as in your other post, then that is likely the problem
typing "determining the force required to break a rope" into google, here's one site on the subject
http://www.digipac.ca/chemical/mtom/contents/chapter1/ltw_001.htm
there are many others
Yes, it is the same author. But in this case: I think his formula is correct.
Who is this author? Please note that PF rules require you to provide a proper reference when asked - and you already ignored that once on your Newton's third law thread.
The formula you quoted isn't valid, let alone correct. Even assuming that the force on the left should be a stress, which would at least make the units correct, you have a differential (dl) on the right and not on the left.
You are talking about tensile strength. I don't think there is a formula for the maximum stress a material can stand. Certainly not a simple one. It's dependent on the way you prepare the material as much as anything else, which is a very complex subject.
It's not correct. It's not even wrong,
I think the formula is valid. I will give my argumentation...
According to me, this is just another form of F=ma. This is an equation which determines how a string stretches dynamically assuming it has zero stiffness (i.e. its spring constant = 0). I suspect that in the equation, density, is in units of Kg per meter of length of the string, not Kg per cubic meter which is how it's normally defined. With this understanding the units work out!
Now, consider a differential length of string, dL.
By Newton's Second Law: Force = mass x acceleration = density x dL x acceleration.
So, stress in the string = density x dL x acceleration.
But force does not break a string, stress does. The string will break when the maximum stress reaches the breaking stress. I think the factor of 2 has something to do with the fact that the maximum stress (or load) is twice the average stress (or load).
We can also say: d2l/dt2 = (F/2) / (ρdl) = F/(2m) (m - mass)
This is my explanation of the quoted equation... I will appreciate every comment. Thank you!
did you not read V50's response ?
I wouldn't argue with some one so well educated ... if he say's it's incorrect, you would do well to believe that :wink:
as has been said to you a number of times now, across several of your threads, you need to start reading and learning some real physics
and forget about books written by philosophers, otherwise you are just going to be led further and further astray
did you go to the link I gave you and study the info there ?
You've gone from reading a poor text to defending a poor text; you've gone from confusion to crackpottery.
You have a choice - accept that you've been led astray by a poor book and start afresh, or to continue to hold an incorrect view and never learn. Up to you.
Likes russ_watters and Nidum
We will not discuss this book further at PF
Likes russ_watters
