String hanging from the ceiling
  • Thread starter Thread starter rbwang1225
    String
The discussion centers on calculating the time it takes for a transverse pulse to travel along a string of length L and mass m, which is supporting an object of mass M. The relevant equation for the time interval is Δt=2√(L/(mg))(√(M+m)-√M). There is uncertainty about whether the waiting time is simply twice Δt. The origin of the equation is explained as being due to varying wave speeds at different points along the string. Understanding this concept is crucial for accurately determining the time for the reflected pulse to return.
rbwang1225
A string of length L and mass m, hanging an object of mass M from the ceiling. After sending a transverse pulse from the top of the string , how much time we have to wait until the reflected pulse returned to the top?
The time interval for a transverse pulse to travel the legth of the rope is ##Δt=2\sqrt{\frac{L}{mg}}(\sqrt{M+m}-\sqrt M)##.
I think the time for waiting is just twice of Δt, but I still concern that maybe I miss something.
Sincerely.
Where does that equation come from?
It is from that different points on the string have posses different wave speeds.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
