Structural Engineering -12x12 stiffness matrix analysis
4 replies · 16K views
elbarto
Hi,
I am trying to write a MATLAB script to do an elastic analysis of 3D frame sturctures. The method I am using is the direct stiffness method, but I cannot find the equations for the 12x12 stiffness matrix for each member in the global system.
If anyone has any information on 3D matrix analysis I would greatly appreciate the help. So far none of the texts I have found have explicitly given these formula.
I have the 6x6 matracies for 2D analysis if anyone is interested.
Thank You
Elbarto
I am assuming that you are using something along the lines of a truss element, but in a 3D structure, i.e. members can carry no bending moments.
Take a look here :
http://www.google.com/url?sa=t&source=web&ct=res&cd=6&url=http%3A%2F%2Fwww.engineer.tamuk.edu%2Fdepartments%2Fieen%2Ffaculty%2FDrLPeel%2FCourses%2FMeen5330%2Fstudent_presentations%2FFEA_F06.ppt&ei=bkvrSKziMdywmQf0mcHaCg&usg=AFQjCNFyXckTs9v56tKt3qI9Yc-c1jALjQ&sig2=k9yvGnIMuqDkYuKnyPc9kg
Towards the back of the presentation it talks about the 3D truss stiffness matrix. Both of my FEA books also discuss this as well. See if you can get a hold of a copy from your library or a fellow student.
Thank you for your reply. That is almost exactly what I am chasing, tho I need the 12x12 stiffness matraix equations because I am considering bending so I will have the 6 additional degree of freedom to account for due to the rotation of each node.
If I find the equations I will post them here. Are you allowed to photo copy pages from textbooks and post them here or is that against forum rules?
Thanks, Elbarto
Yes I am doing a full 3D frame element so I have to consider all 12 DOF's for each member. I had a look in my library today and think I managed to find the local member stiffness equations which will probably work ok if I play around with them a bit but I would appreciate it if you could check your textbook out.
Thanks a lot
Regards Elbarto
