Struggling to understand the concept of spin triplets
  • Thread starter Thread starter jack.d
    Concept Spin
jack.d
hi all, can someone please explain to me why the S=1 state has three projections, i don't understand how the up down coupling produces a total spin of 1 in the triplet but then seems to produce a total spin of 0 in the singlet state with the same orientation.
cheers
OK. So, if I'm reading this correctly, your issue is the following:
\frac{1}{\sqrt{2}}(|\uparrow\downarrow> +|\downarrow\uparrow>)
corresponds to a total spin of 1, while
\frac{1}{\sqrt{2}}(|\uparrow\downarrow> -|\downarrow\uparrow>)
corresponds to a total spin expectation value of 0.
The easiest way to see that this is indeed the case is to explicitly work out the expectation value for the total spin operator:
\hat{S^2}=\hat{S_1}^2+\hat{S_2^2}
You should explicitly see that for the first state the expectation value is s=1, while for the second, s=0.
Another, possibly more physical way to think about the problem is the following:
Consider the Singlet State:
Apply the space rotation operator to the state, and you'll notice that it is invariant under all rotations. Only systems with 0 angular momentum can be rotationally invariant, so we know it's spin must be 0.
Similarly, the m=0 triplet state will not be rotationally invariant, so we know it has some angular momentum.
Thus, even though the states "look" similar, they have very different rotational properties, thus different spin values.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
