Stuck in another static equilibrium problem
The discussion centers on a physics problem involving a board and a person, where the goal is to determine the distance "d" from point "A" at which the board will slide. The weights of the board and person are given, along with the frictional coefficient. Participants discuss the correct approach to solving the problem, highlighting errors in angle calculations and the need for proper moment arm considerations in equations. One participant expresses relief that their method was correct despite minor miscalculations. The conversation emphasizes the importance of precision in calculations and adherence to formatting standards for units.
Femme_physics
At what distance "d", from point "A", the board with the person will slide whereas
http://img267.imageshack.us/img267/6139/skkkkkkk.jpg
Uploaded with ImageShack.us
Weight of board = 50 [kg]
Weight of person = 100[kg]
Frictional coefficient between board and pit: Us = 0.4
c = 3[m] b = 4[m] a =10[m]
((The answer is d = 6.47 [m] ))
I found all the unknowns, but I don't know how to answer the actual question. They're asking for the distance where the plank would slide with the person...can't see how I find that out...
http://img341.imageshack.us/img341/6096/zzzzaf.jpg
Dory: Excellent work, so far. (1) In your summation(Fx) equation, you used the wrong angles inside your two cosine functions. Check that, and correct that equation. (2) In your summation(MA) equation, you forgot to multiply your last two terms by the moment arm (distance) to those two forces. Correct that mistake.
Make the above corrections, and try again. By the way, please do not post wide images directly to the forum page. Just post a text link to wide images.
Ah...so it all comes down to silly miscalculations? I'm glad my method was correct :)
Sorry about the wide images... I got 1600 widescreen so I tend the think the world sees the web like I do :oops:
Many many thanks... I'll work on it!
Got it! :D
Dory: Excellent work. One thing I forgot to mention is, the angle is 36.87 deg, instead of 36.86 deg. But luckily, this did not change the answer.
By the way, always leave a space between a numeric value and its following unit symbol. E.g., 100 [kg], not 100[kg]. See the international standard for writing units[/color] (ISO 31-0[/color]).
Dooly noted... :) thanks
  • · Replies 50 ·
11K
