Stuck on this downhill skiier problem help
  • Thread starter Thread starter Cornraker
    Stuck
A skier reaches a speed of 56 m/s on a 30-degree slope, and the problem involves calculating the minimum distance traveled along the slope from rest, ignoring friction. The key to solving this problem is to find the acceleration down the slope by resolving gravitational acceleration into components. Using the equation v^2 = u^2 + 2as, where v is the final velocity, u is the initial velocity, and a is acceleration, allows for the calculation of distance. The skier's acceleration can be determined using the sine of the slope angle. The solution involves two steps to arrive at the final answer.
Cornraker
A sker reaches a speed of 56 m/s on a 30 degree ski slope. Ignoring friction, what was the minimum distance along the slope the skier would have had to travel, starting from rest?
Which equation do i start with? I'm pretty sure i have to find the x-y component of the acceleration but I'm not sure I'm flat out stuck on this problem.
If i draw a right triangle, and the opposite leg is -9.8 m/s do i use sin30 to find the acceleration down the slope?
You can resolve it in a way that is parallel and perpendicular to the ski slope. So find acceleration and then use the formula v^2 = u^2 + 2as to solve it.
i figured it out. it was two steps
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
