STUPID Vector qusetion - dont understand dot product rule
thomas49th
The points A and B have position vectors a = (2,2,1) and b (1,1,-4) respectively relative to an origin O. (im using column notation for shorthand)
Prove that OA is perpendicular to AB
To be perpendicular the angle between the lines is 90
using the dot product rule:
vectors a and b should multiply to give cos 90 (which is 0)
AB = (3,3,-3)-(2,2,1) = (1,1,-4)
so:
(2,2,1).(1,1,-4) = (2,2,-4)
NOW WHAT I DONT UNDERSTAND IS why you add the components i,j,k to get 0. I can see 2 + 2 -4 =0, but why do you do this? Why can you do this
Simple answer: A dot B is a number (scalar) - not a vector. It's definition is: axbx + ayby + azbz.
You're using row notation. Columns are vertical.
Are you sure you have written the problem correctly? Vectors OA and OB are perpendicular, but OA and AB aren't.
Where did you get (3, 3, 3)? Vector AB = OB - OA, which is (1, 1, -4) - (2, 2, 1) = (-1, -1, -5).
thomas49th said:
so:
It's just ordered-set notation; neither row nor column vectors have commas!
Hi,
You did show that OA is perpendicular to OB. That's good.
I think your question is "Why does the dot-product rule work? Why do you multiply similar components, and then add up the sum?"
Here is one answer that might help you make sense of it:
Look at the dot-product of A.A: it is simply the Pythagorean Theorem.
If A = (ax, ay, az)
Then A.A = ax2 + ay2 + az2.
So ... the dot-product is a method of determining the length of a vector: Lth (A) = \sqrt{A.A}
That's just an example to make you feel comfortable with the rule - because it's useful and makes sense in that situation.
Good luck.
BobM
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
