MHB How to Combine Sturm-Liouville Equations for 4th Derivative?
  • Thread starter Thread starter Dustinsfl
    Derivative
Dustinsfl
X^{(4)}_n - \alpha^4X_n = 0\qquad\qquad X^{(4)}_m - \alpha^4X_m = 0
\begin{alignat*}{7}
X(0) & = & 0 &\qquad\qquad & X'(0) & = & 0\\
X(L) & = & 0 &\qquad\qquad & X''(L) & = & 0
\end{alignat*}
Using a Sturm-Liouville methodology:
Show that the these two equations can be combined in the following manner
X^{(4)}_nX_m - X^{(4)}_mX_n + (\alpha^4_n - \alpha_m^4)X_nX_m = 0
I am not sure how to start this.
\begin{alignat*}{7}
\end{alignat*}
So I have something that makes sense and fits the idea but not entirely.
Let $\phi,\psi$ be sufficiently differentiable functions on $[0,L]$.
Then
\int_0^L\phi^{(4)}\psi dx
after integration by parts 4 times we have
\int_0^L\phi^{(4)}\psi dx - \int_0^L\phi\psi^{(4)} dx =\left[\phi'''\psi - \phi''\psi' + \phi'\psi''-\phi\psi'''\right|_0^L
If $\phi = X_n$ and $\psi = X_m$ and $X^{(4)} = \alpha^4X$, then
\int_0^LX_n^{(4)}X_m dx - \int_0^LX_nX_m^{(4)} dx =(\alpha^4_n-\alpha^4_m)\int_0^LX_nX_m =\left[\phi'''\psi - \phi''\psi' + \phi'\psi''-\phi\psi'''\right|_0^L
So how do I get from here to where I am trying to go?
Then
So here is what I think. Is this correct?
Differentiating and multiplying through by negative yields
X_nX_m^{(4)} - X_n^{(4)}X_m + (\alpha^4_m - \alpha^4_n)X_nX_m = 0.
Since the order of $n^{\text{th}}$ and the $m^{\text{th}}$ mode is irrelevant, the result is the same. Thus, we can just switch the subscript.
\begin{alignat}{3}
X_mX_n^{(4)} - X_m^{(4)}X_n + (\alpha^4_n - \alpha^4_m)X_nX_m & = & 0.
\end{alignat}
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
