Substitution differential equation problem
Michels10
Solve y' = y/x + 1/y
I get a similar answer to the correct one but I believe I am making a substitution error. Here is my attempt:
dy/dx = y/x + 1/y
set v = y/x
equation now becomes: v + x(dv/dx) = v + 1/(x*v)
reduces to: dv/dx = 1/(x^2 * v)
Now the equation is seperable, so I separate and take the integral of both sides yielding:
v = (sqrt(-2) * sqrt(x*c - 1))/sqrt(x)
--even if i substitute v = y/x back in it doesn't come out to be the correct solution of:
y = sqrt(x) * sqrt(x*c -2)
Any insight would be great!
Nevermind, solved it. Needed to substitute v=y^2.
Thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
