Subtraction of real function from another
  • Thread starter Thread starter Abu Rehan
    Function
Abu Rehan
We define subtraction of real functions as (f-g)(x) = f(x) - f(x). But I wonder what does (f-g) mean! I don't find any meaning in (sin - (square of))(x).
If it really has any meaning then tell with examples.
Mathematics news on Phys.org
h = f -g denotes the actual function which takes an element x in the domain (here it's the intersection of the domains of f and g) and outputs f(x) - g(x). This is why we write (f-g)(x) = f(x) - g(x). Remember f and g are functions, not numbers, whereas f(x) and g(x) are real numbers, if f and g are real valued. While it's important to keep in mind the distinction between a function f and the values of its output f(x) (x in the domain of f), it's rather common to write f(x) to denote the function (e.g. among mathematical analysts), usually for convenience.
In the example you give (sin - (square of))(x) would equal sin(x) + x^2. It's really just that simple.
The whole purpose of "(f- g)(x)= f(x)- g(x)" is to tell you what f- g means.
(sin- square of)(x) is, according to that definition, sin(x)- square of (x)= sin(x)- x^2
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
