What Are the Best BJTs for a 17.5 MHz Pulse Input Application?
The discussion focuses on selecting BJTs for a 17.5 MHz pulse input application with a voltage range of +15V to -3V and a load capacitor of 150pF, requiring rise and fall times of 10ns. Participants suggest considering both NPN and PNP transistors, noting that RF transistors may struggle with the required load and current specifications. A specific mention of the 2N5770 NPN transistor is made, which is suitable for faster rise times but operates at lower voltage levels. The importance of maintaining transistor conduction without saturation for optimal pulse performance is highlighted. Overall, the conversation emphasizes the need for careful selection of transistors to meet the stringent timing and voltage requirements.
VASANSNS
Hello everybody,
I have an application which needs a pulse input ranging from +15v to -3v operating at 17.5 Mhz. The load capacitor is 150pF and the required rise and fall time of the pulse is 10nS. I am building a circuit with BJT's (both NPN and PNP) . I need some idea about the criteria for selection of BJT's available in the market.
Can somebody suggest some available NPN and PNP transistors which work in this range.
Also i tried searching for some RF transistors, but i was not sure if they are capable of handling such huge loads. The max collector current for RF transistors was around 50mA. I was not whether its possible to get such a strict rise/fall time with the given load. Can somebody comment on this calculations.
Also any other suggestion or reference links are also welcomed.
Regards
SNS
I used to use a 2N5770 npn for 1-2 ns risetime pulses, but it was only about a 0.75 volt to 1.5 volt pulse into 50 ohms. Are you talking about a pulse that goes from 15 volts to -3 volts? Into what impedance? To get the fastest pulses, always keep the transisitor conducting, but never in saturation.
Bob S
What is your application? Electro-optic modulator? Polarisation scrambler maybe?
Image Sensor Driver
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
