Solve 1729 as Sum of 2 Cubes: Natural Numbers
  • Thread starter Thread starter cragar
    Sum
1729 is the smallest positive integer expressible as the sum of two cubes in two distinct ways using natural numbers. The equation x^3 + y^3 = 1729 can be approached analytically by factoring it as (x + y)(x^2 - xy + y^2). Participants in the discussion suggest using guess and check methods, while also recalling techniques involving complex numbers and moduli for similar problems. The conversation highlights the historical significance of 1729, often referred to in mathematical anecdotes. Ultimately, the focus remains on finding the two specific pairs of natural numbers that satisfy the equation.
cragar
1729 is the smallest positive integer that can be represented in two different ways as the sum of two cubes , what are the two ways.
They have to be natural numbers.
x^3+Y^3=1729 i could just find the answer by guess and check , but I am not sure how to do it analytically.
You can simplify a little by using x^3+ y^3= (x+ y)(x^2- xy+ y^2).
Now, factor 1729 to find two factors that would fit that.
sweet thanks for the help
I remember my teacher showing us a method with complex numbers and moduli to find the sum of two squares to equal some number we have. If only I remember the method... Maybe this can be extended to the sum of two cubes?
You can't not know the oft-told tale about this question and this number?
There is a very oft-told tale about this question with this number many people here will know.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
