Finding the First Term and Common Difference of an Arithmetic Series
In summary, the conversation discussed the formula for finding the sum of an arithmetic series, which is S = (n/2)(2a + (n-1)d). It was explained that to use this formula, you need to know the number of terms, the first term, and the common difference. The difference between an arithmetic series and a geometric series was also mentioned, with the key difference being a constant difference versus a constant ratio between terms. The conversation then discussed how the sum of an arithmetic series can be used to find a missing term by rearranging the formula and solving for the missing term. Finally, it was mentioned that the sum of an arithmetic series has real life applications in areas such as finance and data analysis.
Blister
The sum of the first 4 terms in an arithmetic series is -8 and the sum of the first 5 terms is 85. Determine the first term and the common difference.
tn = a + (n-1)d
Sn = n/2 (2a + (n-1)d)
Blister said:
I think you forgot to type in this section.
Using the given equations, we can set up a system of equations to solve for the first term (a) and the common difference (d).
For the first equation, we can substitute n=4 and Sn=-8:
-8 = 4/2 (2a + (4-1)d)
-8 = 2(2a+3d)
-8 = 4a+6d
For the second equation, we can substitute n=5 and Sn=85:
85 = 5/2 (2a + (5-1)d)
85 = 5(2a+4d)
85 = 10a+20d
We now have a system of equations with two unknowns (a and d). To solve this, we can use the method of elimination. By multiplying the first equation by 5 and the second equation by 2, we can eliminate the variable "a" and solve for "d". This gives us:
-40 = 20a+30d
170 = 20a+40d
Subtracting the two equations, we get:
-210 = 10d
d = -21
Now, we can substitute this value of d back into either of the original equations to solve for a. Using the first equation, we get:
-8 = 4a+6(-21)
-8 = 4a-126
118 = 4a
a = 29.5
Therefore, the first term of the series is 29.5 and the common difference is -21. We can check our solution by plugging these values into the equations:
t4 = 29.5 + (4-1)(-21) = -44.5
t5 = 29.5 + (5-1)(-21) = -65.5
S4 = 4/2 (2(29.5) + (4-1)(-21)) = -8
S5 = 5/2 (2(29.5) + (5-1)(-21)) = 85
Therefore, our solution is correct and the first term and common difference for the given arithmetic series are 29.5 and -21, respectively.
What is the formula for finding the sum of an arithmetic series?
The formula for finding the sum of an arithmetic series is:
S = (n/2)(2a + (n-1)d), where S is the sum, n is the number of terms, a is the first term, and d is the common difference.
How do you find the sum of an arithmetic series using the formula?
To find the sum of an arithmetic series using the formula, you need to know the number of terms, the first term, and the common difference. Plug these values into the formula:
and solve for S to find the sum.
What is the difference between an arithmetic series and a geometric series?
An arithmetic series is a sequence of numbers with a constant difference between each term. A geometric series is a sequence of numbers with a constant ratio between each term. In other words, in an arithmetic series, each term is obtained by adding a constant value to the previous term, while in a geometric series, each term is obtained by multiplying the previous term by a constant value.
How can you use the sum of an arithmetic series to find a missing term?
You can use the sum of an arithmetic series to find a missing term by rearranging the formula:
to solve for the missing term, a:
a = (S - (n/2)d) / n
Once you have the value of a, you can use it to find any missing term in the series.
How is the sum of an arithmetic series useful in real life situations?
The sum of an arithmetic series is useful in many real life situations, such as calculating total earnings or expenses over time, determining the total distance traveled during a trip with a constant speed, or finding the average of a set of data. It can also be used in financial planning to calculate the total value of an investment over time.
  • Precalculus Mathematics Homework Help
