How do you calculate the sum of this infinite series?
In summary, the sum of the given infinite series is given by the formula a / (1-r), where a is the first term and r is the common ratio. In this case, a = (5/7)2 and r = -5/7. However, since the first term is 0, the formula becomes a little more complicated. After some algebraic manipulation, the sum can be rewritten as (-5/7)2 / (1-(-5/7)), which simplifies to 25/49 / (12/49), or 25/12.
astroboy17
I am trying to understand how to calculate the sum of the following
infinite series, can someone help please:
(5/7)2 - (5/7)3 + (5/7)4 - (5/7)5 + ...
The sum of such a series should be given by:
a / (1-r)
But the value of a = 0 (the first term = 0), hence my confusion.
Thanks
Mathematics news on Phys.org
The value of a is 1
Rewrite the series with (5/7)2 factored out.
(5/7)2(1 - 5/7 + (5/7)2 -+ ...)
Now can you see that a = 1 as VeeEight suggested?
If a = 0, all the terms will be 0.
Another point, the formula you quoted gives the limit of the sum of powers from 0 to n as n goes to infinity:
[tex]\frac{1}{1-r} = \sum_{k=0}^{\infty} \left( -\frac{5}{7} \right)^k = 1 -\frac{5}{7} + \left(\frac{5}{7}\right)^2 - \left(\frac{5}{7}\right)^3 + ...[/tex]
But your sum is missing the first two terms,
[tex]\left( -\frac{5}{7} \right)^0 = 1, \left( -\frac{5}{7} \right)^1 = -\frac{5}{7}.[/tex]
So what you have is:
[tex]\sum_{k=2}^{\infty} \left( -\frac{5}{7} \right)^k = \frac{1}{1-r} - 1 - \left( -\frac{5}{7} \right).[/tex]
The general formula for a geometric series where the summation index begins at some value, m, not necessarily 0, is
[tex]\frac{ar^m}{1-r}, |r| < 1.[/tex]
http://en.wikipedia.org/wiki/Geometric_progression#Geometric_series
Astroboy, just use a=25/49 and r=-5/7 in the formula you already posted.
Hi astroboy17! :wink:
A different way of doing it to to say let the sum be S …
then if you divide S by (5/7)2, you get S + 1 - 5/7 …
ie (7/5)2S = S + 2/7 …
carry on from there. :smile:
Then we can still use the formula
[tex]\frac{a}{1-r}[/tex]
if we just redefine a as (-5/7)2, so:
[tex]\sum_{k=2}^{\infty}\left ( -\frac{5}{7} \right )^k = \sum_{k=0}^{\infty} \left(-\frac{5}{7} \right )^2 \left( -\frac{5}{7} \right )^k[/tex]
[tex]= \left(-\frac{5}{7} \right )^2 \enspace \frac{\sum_{k=2}^{\infty} \left( -\frac{5}{7} \right )^k}{\left(-\frac{5}{7} \right )^2}[/tex]
[tex]= \frac{\left( -\frac{5}{7} \right )^2}{1-\left( -\frac{5}{7} \right )}.[/tex]
1. What is the sum of an infinite series?
The sum of an infinite series is the total value obtained by adding up all the terms in the series. This value is often denoted by the Greek letter sigma (Σ).
2. How do you find the sum of an infinite series?
The sum of an infinite series can be found by using a mathematical formula or by using convergence tests to determine if the series converges to a finite value. Some common methods for finding the sum include the geometric series formula and the telescoping series technique.
3. Can an infinite series have a finite sum?
Yes, it is possible for an infinite series to have a finite sum. This occurs when the terms in the series approach zero as the number of terms increases, resulting in a convergent series. However, not all infinite series have a finite sum, as some may diverge to infinity.
4. What is the difference between a convergent and a divergent infinite series?
A convergent infinite series is one that has a finite sum, meaning that the terms in the series approach a specific value as the number of terms increases. On the other hand, a divergent infinite series is one that does not have a finite sum, meaning that the terms in the series do not approach a specific value and the series can either increase or decrease without limit.
5. How is the sum of an infinite series used in real-world applications?
The concept of infinite series and their sums is used in various fields of science and mathematics, including physics, engineering, and economics. For example, in physics, the sum of an infinite series is used to calculate the total energy of an object, while in economics, it can be used to model compound interest. Infinite series are also used in computer algorithms and simulations to solve complex problems.
  • General Math
  • General Math
  • General Math
