Can Two Future-Pointing Null Vectors Sum to a Time-Like Vector?
  • Thread starter Thread starter spaghetti3451
    Sum Vectors
The sum of two future-pointing null vectors results in a future-pointing time-like vector unless the vectors are parallel, in which case the sum remains null. Any time-like vector can be expressed as the sum of two null vectors, but these null vectors are not uniquely determined. The freedom in choosing these null vectors lies in the condition that they must either both point forward or both point backward in time. This discussion clarifies the relationships between null and time-like vectors in the context of spacetime geometry.
spaghetti3451
Show that the sum of two future-pointing null vectors is a future-pointing time-like vector, except when the two null vectors have the same direction. Conversely, show that any time-like vector can be expressed as a sum of two null vectors. For a given time-like vector the two null vectors are not uniquely determined: what is the nature of the freedom in their choice?
Under the 'mostly-minus' convention, a null vector ##N^{a}## satisfies ##N^{a}N_{a}=0##, a time-like vector ##T^{a}## satisfies ##T^{a}T_{a}>0##, and a space-like vector ##S^{a}## satisfies ##S^{a}S_{a}<0##.
Given a future-pointing time-like vector ##P^{a}## (with ##P^{0}>0##), any other future-pointing time-like or null vector ##Q^{a}## satisfies ##P^{a}Q_{a}>0##.
Consider two future-pointing null vectors ##P^{a}## and ##Q^{a}##. These vectors satisfy the following relations:
##P^{a}P_{a}=0,\ Q^{a}Q_{a}=0,\ P^{a}Q_{a}>0##.
Therefore, ##(P^{a}+Q^{a})(P_{a}+Q_{a}) = P^{a}P_{a}+ 2\ P^{a}Q_{a} + Q^{a}Q_{a} = 2\ P^{a}Q_{a}##.
Now, if ##P^{a} \not\propto Q^{a}##, then ##(P^{a}+Q^{a})(P_{a}+Q_{a}) = 2\ P^{a}Q_{a} > 0## and
if ##P^{a} \propto Q^{a}##, then ##(P^{a}+Q^{a})(P_{a}+Q_{a}) \propto 2\ P^{a}P_{a} = 0##.
Therefore, the sum of two future-pointing null vectors is a time-like vector, except when the two null vectors have the same direction, in which case the sum is again a null vector (regardless of the time-orientation of the original two vectors).Consider a time-like vector ##S^{a}+T^{a}##, where the nature of ##S^{a}## and ##T^{a}## are not yet known. The vector ##S^{a}+T^{a}## satisfies the following relation:
##(S^{a}+T^{a})(S_{a}+T_{a})>0##, which means that
##S^{a}S_{a}+T^{a}T_{a}+2S^{a}T_{a}>0##
Where do I go from here?
What happens if you now choose S and T to be null-like?
If ##S^{a}## and ##T^{a}## are null-like, then ##S^{a}T_{a}>0##
which means that ##S^{a}T_{a}## has to be future-pointing as well.But then, the relation ##S^{a}S_{a}+T^{a}T_{a}+2S^{a}T_{a}>0## is also satisfied for ##S^{a}## and ##T^{a}## future-pointing time-like?
Yes, the question asks you to show that a time-like vector can be expressed as a sum of two null vectors; it did not say that that is the only way to decompose it. I don't see why you can't express a time-like vector as a sum of two time-like vectors if you wanted to.
Thanks! Got it!
Let me now answer the third part of the question:
For a given time-like vector, the two null vectors are not uniquely determined: what is the nature of the freedom in their choice?
The condition for the vectors ##T^{a}## and ##S^{a}## to be null is that ##T^{a}S_{a}>0##,
so either both vectors are future-pointing, or both are past-pointing.
Is this correct?
Yup, that seems right to me.
At first, I derived that: $$\nabla \frac 1{\mu}=-\frac 1{{\mu}^3}\left((1-\beta^2)+\frac{\dot{\vec\beta}\cdot\vec R}c\right)\vec R$$ (dot means differentiation with respect to ##t'##). I assume this result is true because it gives valid result for magnetic field. To find electric field one should also derive partial derivative of ##\vec A## with respect to ##t##. I've used chain rule, substituted ##\vec A## and used derivative of product formula. $$\frac {\partial \vec A}{\partial t}=\frac...
Thread 'Conducting Sphere and Dipole Problem'
Hi, I'm stuck at this question, please help. Attempt to the Conducting Sphere and Dipole Problem (a) Electric Field and Potential at O due to Induced Charges $$V_O = 0$$ This potential is the sum of the potentials due to the real charges (##+q, -q##) and the induced charges on the sphere. $$V_O = V_{\text{real}} + V_{\text{induced}} = 0$$ - Electric Field at O, ##\vec{E}_O##: Since point O is inside a conductor in electrostatic equilibrium, the electric field there must be zero...
