Proving the Summation Problem: P(x) and the Limit of |e^(x-1)-1| for x>0
The discussion focuses on proving that if |P(x)| is bounded by |e^(x-1)-1| for all x > 0, then the sum of the coefficients weighted by their indices, |∑(r*a_r)|, is less than or equal to 1. It is established that P(1) must equal zero, leading to the conclusion that the sum of the coefficients a_0, a_1, and a_2 must be less than or equal to 1. The derivative P'(1) is expressed as the weighted sum of coefficients, which is equal to a_1 + 2a_2 + 3a_3 + ... The derivative of e^(x-1)-1 at x=1 is determined to be 1, indicating that P'(1) must lie between -1 and 1. This supports the assertion that |∑(r*a_r)| is indeed less than or equal to 1.
AdityaDev
If ##|P(x)|<=|e^{x-1}-1|## for all x> 0 where ##P(x)=\sum\limits_{r=0}^na_rx^r## then prove that ##|\sum\limits_{r=0}^nra_r|<=1##
None
##P(1)=a_0+a_1+...##
If the constants are positive, then ##P(1)<=|e^0-1|##
So P(1)<=0
so ##a_0+a_1+a_2+... <=1##
But how do I prove that ##0a_0+1.a_1+2.a_2+...<=1##
None
So P(1)<=0
Uh, ##P(1)=0##. Say why that's true. Then you want to show ##|P'(1)| \le 1##. Think about considering what the derivative of ##e^{x-1}-1## at ##x=1## might tell you about that.
Likes AdityaDev
|P(1)|<=0. So the only possibility for P(1) is zero.
P'(1)=a1+2a2+3a3+...
Derivative of ##e^{x-1}-1## at x=1 is 1. So P'(1) lies between 1 and -1.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
