Summing up binomial coefficients
The discussion focuses on simplifying a complex expression involving binomial coefficients. Participants suggest expanding squares and using specific values for n to identify patterns. They emphasize the symmetry and properties of binomial coefficients, recommending the creation of a cheat sheet for reference. Additionally, they propose using cube roots of unity to analyze the behavior of the series. The conversation highlights the challenge of simplifying the second series while building on the first series simplification.
utkarshakash
The value of ((^n C_0+^nC_3+...) - \frac{1}{2} (^nC_1+^nC_2+^nC_4+^nC_5+...))^2 + \frac{3}{4} (^nC_1-^nC_2+^nC_4-^nC_5...)^2<br />
I can see that in the left parenthesis, the first bracket contains terms which are multiples of 3 and in the second bracket, those terms are missing. I know it's a much less attempt from my part but that's all I can see. Please help XO
Sums go to n?
Have you tried expanding out the squares?
You'll need extra binomial coefficients.
The coefficients have a symmetry amongst other properties - you should make a cheat-sheet of the basic properties.
Also - try n=2 and n=3 and expand them out explicitly and see if you find a pattern.
BTW: what was the question?
Try using powers of a cube root of 1. E.g. look at how the imaginary parts of those change and compare it with the behaviour of the last series.
I could simplify the first series to
'\dfrac{(\omega ^2n + \omega ^n)^2}{4}
But I still can't get the second one. Here's my attempt
(1+\omega)^n + (1+ \omega ^2)^n = 2(C_0+C_3+...) - (C_1+C_2+C_4...)
Consider other linear combinations of (1+1)n, (1+ω)n, (1+ω2)n.
