Sun-Earth System given center of mass
The problem involves the Sun and the Earth as a system of two particles, focusing on the calculation of the center of mass and its position relative to the Sun and Earth. Participants are tasked with determining the distance L from the center of the Sun to the center of mass and comparing it to the radius of the Sun.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the center of mass equation and its application, with some expressing uncertainty about how to start the calculations. Questions arise regarding the choice of the origin for the reference frame and how it affects the calculations.
Some participants have offered guidance on using the center of mass equation, while others emphasize the importance of performing the calculations to determine the position of the center of mass. There is recognition that different choices for the origin will yield the same result, but one choice may simplify the process.
Participants mention confusion regarding the initial setup and the specific values to use in the calculations. There is an acknowledgment of the need for clarity on the reference frame and the parameters involved in the problem.
disque
Consider the Sun and the Earth as a 'system' of two 'particles'. The center of mass of this system lies a distance L from the center of the Sun. Find L and compare it to the radius of the Sun.
The center of mass of the Earth-Sun system lies?
A. inside the radius of the Sun
B. inside the radius of the Sun
C. inside the radius of the Earth
I have no clue where to start, I know the center of mass equation but I don't know if that has any significance or what. Thank you in advance!
What is that equation? Try using it. We can't help you until you make some kind of start.
Well, center of mass equation is (m_1r_1+m_2r_2)/(sigma)m_1)
I know the center of mass of the 2 is in the radius of the sun because the suns size compared to earth, but i don't know the first part still?
How do you know that unless you do the calculations? If you do the calculations the answer will pop right out. The distance from the center of the Sun to the Sun-Earth center of mass will either be smaller than or larger than the radius of the Sun. If it's smaller the center of mass is inside the Sun. Larger, and the center of mass is outside of the Sun.
In short, you need to do the calculation.
Im having the same problem, I know the center of mass equation
(M1r1+M2r2)/ sigma (m)
but is the center of the sun the origin? so would M1xR1 just be 0?
What I am confused about is what do I plug in for what?
I already tried calculating the distance from the center of the sun to the center of the Earth to use as r2 but it didn't work.
In answering this question it does not matter one bit which point you choose as the origin of your reference frame in the sense that they will all the same answer. However, one specific choice will make it much easier to answer the question.
You picked that "best" choice, shaanyr.
Show your work.
  • · Replies 25 ·
17K
