Superposition and electronic circuits
2 replies · 3K views · last reply
Kobayashi
Can someone please explain to me how to find the voltage across BD in the attached circuit. I can't do these examples. Please help.
When I shorted one source I get the source current as 10.08mA and a voltage drop across the 200 ohm resistor of 2.02V.
  • Circuit schematic: a 5.04V battery on the left in series with a 200 ohm resistor and a 300 ohm resistor, then a -3.71V battery on the right, with nodes B and D marked on the wire path.
I think your drawing is missing the current source? Be that as it may, REMEMBER: SHORT current sources and OPEN voltages sources. Do that, give us a complete drawing and show your work and we can help you if needed.
Ok, assuming that the circuit is correct, V_BD= V acrosss 300ohms + 3.71V. You need to find that voltage by using KVL.
Hope that helps.
