How Would a Change in Electron Spin Alter the Identity of Noble Gases?
dalarev
Suppose that electrons had a spin number of \frac{3}{2} instead of \frac{1}{2}
That is, they have ould magnetic spin states of S_{z} = \frac{-3}{2}\hbar , \frac{-1}{2}\hbar , \frac{+1}{2}\hbar , \frac{+3}{2}\hbar
Which elements would be the "new" noble gases in this case?
"real" electron spin = + 1/2, - 1/2.
Noble gases are in the group of Helium (Neon, Argon, etc.)
I figured it was going to be easy because, looking at the dependence of the other 3 quantum numbers on each other, it would reveal the solution quickly. The dependence I'm referring to is n = 1, 2, 3, ...
l = 1, 2, n-1... and so on..
I can't find a dependence this clear with the spin number though.
Hint: what is so special about the nobel gases?
l = n-1, always, for noble gases. Where does m_{s} come into play?
The total number of m states gives the total number of electrons which may share the same n, l states. A noble gas is an element where all of its electron shells are completely full...
... and instead of TWO electrons filling each N-L orbital, ...
How do you build up the electron stucture for helium & neon
Does a pattern reveal?
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
