Surface area limited with two functions
14 replies · 4K views
theakdad
I have to calculate the surface area limited with two functions:
$$g(x)=2$$ and $$h(x)=\frac{4}{4x^2+1}$$
i was thinking first to calculate the points where this functions are intersecting by $$g(x)=h(x)$$ and to find corresponding $x$ for the intersection...and then to calculate definite integral somehow. Am i on the right path? Thank you for your help!
Yes, you are on the right path.
You may also utilize the even symmetry of the bounding functions to find only the first quadrant area, and then double that to get the total area.
Have you found the first quadrant point of intersection?
So intersections are: $$-\frac{1}{2}, \frac{1}{2}$$
Correct. Have you determined which function is the "top" function on the relevant interval?
its $g(x)$
wishmaster said:
its $g(x)$
Pick a test value for $x$ in the interval $$\left(-\frac{1}{2},\frac{1}{2} \right)$$. I would suggest $x=0$ for simplicity.
Which function is greater at $x=0$?
Its $h(x)$, I am sorry.
Correct. Now, can you write the definite integral representing the area bounded by the two functions?
$$S=\int_a^b(h(x)+C)-\int_a^b(g(x)+C)$$ where $a$ is $$-\frac{1}{2}$$ and $b$ is $$\frac{1}{2}$$ ??
No, you want:
$$S=\int_{-\frac{1}{2}}^{\frac{1}{2}}\left[h(x)-g(x) \right]\,dx$$
Since the integrand is even and the limits to integration also symmetric about the $y$-axis, we may use the even-function rule to state:
$$S=2\int_{0}^{\frac{1}{2}}\left[h(x)-g(x) \right]\,dx$$
MarkFL said:
No, you want:
i will need some time to figure this out...
Here is a plot of the area to be found:
Can you see the symmetry now?
I see,yes. Whats the software you use to write graphs?
You haven't yet done the integration so there should be no "C".
