NanakiXIII said:
I just had a look and if you just assume that the event horizon happens where the rr component of the Kerr metric blows up, you find that the radius is r = M + \sqrt{M^2-a^2}. This is what Wikipedia (
http://en.wikipedia.org/wiki/Kerr_metric#Important_surfaces) does. First of all, it seems ad hoc to me, I don't know why this might be a good radius to choose. Second, the radius is apparently \sqrt{r^2 + a^2} = \sqrt{2Mr} and not just r.
This is the same as the equation in post #3, r_+=M+\sqrt{(M^2-a^2-Q^2)}, just minus the charge and represents the coordinate radius for the event horizon. You could say that the coordinate distance is a radial distance where as the reduced circumference is the path that light would take, the coordinate distance being a geometric measurement, the reduced circumference being a geodesic. For a static black hole, these are equal because there is no frame dragging, but for a rotating black hole, light that was originally on a radial path, spirals into the BH and the path it takes is longer than the geometric radius from where it originated. Its this distance (reduced circumference) that is referred to when calculating surface area of the EH, centripetal acceleration of objects rotating the BH, etc. as it is (for want of a better expression) a truer distance.
The reduced circumference is derived from Kerr metric. An exact solution (relative to the azimuth) is-
\sqrt{g_{\phi\phi}}\ =\ \varpi=\frac{\Sigma}{\rho}sin\theta
where
<br />
\]<br />
\Sigma^2=(r^2+a^2)^2-a^2\Delta sin^2\theta\\<br />
\\<br />
\Delta= r^{2}+a^{2}-2Mr\\<br />
\\<br />
\rho^2=r^2+a^2 cos^2\theta<br />
\[<br />
symbols you'll recognise if you look at Kerr metric (which I recommend). You'll find at the equator, regardless of spin, the reduced circumference for the outer event horizon (r
+) equals 2M. Why simply (r_+^2 +a^2) is used to represent this in the surface area calculation isn't crystal clear but according to a number of sources, it appears to be the norm and is equivalent to equation A = 16 \pi M_{ir}^2. Regarding your OP, you might be worth crunching some numbers to see how M compares to M
ir for a black hole with spin.
