Bonavaero
- 4
In selecting starter motor for a gas turbine, which minimum torque or inertia is it supposed to overcome, it that of the compressor or the turbine, or both.
Combustion sustained refers to the process of maintaining a continuous and stable combustion reaction within an engine. This is crucial for the engine to function properly. The starter motor torque is the force generated by the starter motor to rotate the engine's crankshaft and initiate the combustion process. Therefore, selecting the appropriate starter motor torque is essential for ensuring successful combustion sustained.
Inertia selection refers to the selection of an appropriate moment of inertia for the starter motor, which determines its ability to overcome the resistance of the engine and rotate the crankshaft. This is crucial for achieving successful combustion sustained as it affects the speed and efficiency of the starter motor in initiating the combustion process.
Starter motor torque and inertia selection are determined by various factors such as the type and size of the engine, the fuel used, and the desired speed and efficiency of the engine. This requires careful analysis and calculations by engineers and scientists to select the most suitable torque and inertia for the specific engine.
If the starter motor torque is too low, it may not be able to rotate the crankshaft and initiate the combustion process, leading to engine failure. On the other hand, if the torque is too high, it can cause damage to the engine components. Similarly, incorrect inertia selection can result in inefficient combustion and potential damage to the engine.
Maintaining the appropriate starter motor torque and inertia for long-term combustion sustained requires regular maintenance and monitoring of the engine. Any changes in the engine's performance should be promptly addressed to ensure that the torque and inertia remain at optimal levels. Additionally, using high-quality and properly sized starter motors can also help in maintaining long-term combustion sustained.
