Switcing DC on an off repeatedly 'laymans question'
  • Thread starter Thread starter Robin07
    Dc
Switching DC current on and off at a high frequency, such as 60 times per second, creates a pulsed DC signal, which can resemble AC but retains a unidirectional flow characteristic of DC. This pulsed DC can be filtered through a capacitor to produce an AC square wave by removing the DC bias. The discussion highlights the importance of capacitors in this process, particularly in how they charge and discharge in response to voltage changes. A capacitor in series with a resistor can facilitate this behavior, allowing for voltage variations that reflect the pulsed input. Understanding these principles is essential for effectively using capacitors in circuits involving pulsed DC signals.
Robin07
I realize that this may be an unlearned question.
Is switching DC current, on and off, let's say 60x/sec, similar or exactly the same as AC. From a laymans point of view it is not. I may stand to be corrected but, AC indicates that the current flows, or is switched to flow, in opposite directions and DC, be it switched or not, will still flow only in one direction...
Thanks for your patients
Your understanding is correct. What you describe is often termed pulsed DC and it can also be thought of as AC with a DC bias--if you put this signal through a capacitor, the DC component is removed and you're left with an AC square wave.
I read through Wikipedia's description in regards to 'capacitors and DC bias. Thanks negitron, not that I understand it all or even a small percentage, there is so much for me to learn.
OK, so I'm looking for a capacitor that will reach equilibrium with the source voltage, at that point the current through the entire circuit will decay. In essence discharging a charged capacitor, returning the entire circuit to zero, hence the square wave...yes?
Do you have a recomemdation to which type of capacitor I should be looking at?
Imagine a capacitor in series with a resistor to ground.
Apply a positive voltage to the open end of the capacitor. It will charge up via the resistor until there is no voltage across the resistor and all the voltage is across the capacitor.
Now briefly connect the open end of the capacitor to ground.
The capacitor doesn't have time to discharge, so the voltage across the resistor goes negative by the amount that the capacitor was charged to.
Now briefly connect the capacitor to double the previous voltage. Again, the capacitor doesn't get time to charge more and the voltage across the resistor plus the voltage across the capacitor equals the new voltage, so the resistor voltage equals the increase in voltage.
This is how capacitive coupling works.The capacitor stays charged to the DC voltage, but the changes in voltage are passed through to the other side.
In the case you describe, a pulsed wave of say 5 volts alternating with 0 volts would charge the series capacitor to 2.5 volts and give square wave output swinging from +2.5 volts to -2.5 volts
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
