Symmetric group S3 with symbols
mikael27
Determine the orders of all the elements for the symmetric group on 3 symbols S3.
_______________________________________
3 symbols : e,a,b
I don't know how to do the S3 table using just these 3 letters
I can do it using 6 letters (e,s,t,u,v,w) which is going to be like this:
e s t u v w
s e v w t u
t u e s w v
u t w v e s
v w s e u t
w v u t s e
3. The Attempt at a Solution [/b
3 symbols : e,a,b
e s t u v w
s e v w t u
t u e s w v
u t w v e s
v w s e u t
w v u t s e
the "symbols" of S3 in this case aren't the elements, they are the elements of the domain of the functions that make up S3.
ok, what S3 is, is the group of permutations of 3 "things". sometimes the things are called "letters", sometimes they are taken to be the elements of the set {1,2,3}. but what an element of S3 IS, is a certain kind of function: namely, a bijection on a 3-element set with itsef. all 3-element sets are pretty much alike (as sets), they just have different "element-names". so it doesn't really matter if you call the element (1 2) in S3 the function:
1→2
2→1
3→3
or:
a→b
b→a
c→c
what we actually mean by (1 2) is:
"the function on a 3-element set that swaps the first and second elements".
there are 6 possible bijections on the 3-element set A = {a,b,c} (you can think of a = 1, b= 2, and c = 3 if you want to, but the properties of 1,2 and 3 as integers aren't relevant here. it's better to think of them as:
a = "element number 1"
b = "element number 2"
c = "element number 3").
one of the 6 possible bijections is:
a→a
b→b
c→c
better known as: the identity function on A: f(x) = x, for all x in A.
there are 3 bijections (permutations) of A that interchange 2 elements, and 2 bijections of A that send all 3 "to something else". see if you can puzzle out what these mappings might be. then give all 6 maps a name.
multiplication on S3 is functional compostion. so if f is in S3, you want to answer the following question:
"what is the smallest postive integer n, for which f°f°...°f(x) = fn(x) = x, for all x in A?"
that integer is the order of f.
for our example f =
a→b
b→a
c→c,
f2 =
a→b→a
b→a→b
c→c→c
so f2(x) = x, for all x in A, that is: f2 = idA, so the order of f is 2, in this case. 1 down, 5 to go.
I have merged the two threads. Please do not post the same question more than once.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
