Syringe/Stepper Motor Pump Design
  • Context: Plumbing
  • Thread starter Thread starter Frank-95
    Design Motor Pump
9 replies · 7K views
Frank-95
TL;DR
I need to calculate the output pressure of a syringe pump driven by a stepper motor, given the step-rate of the motor itself, and the length of the tube connected to the syringe.
Hello.
I've built this syringe pump. The chosen motor is a NEMA 11 with a maximum torque of 6 Ncm.
The thread rod is an M5 with a pitch of 0.8 mm.
The whole system will consist also of a long tube (1 m length, 3.175 mm external diameter, 1.5875 internal diameter), at the end of which I'll need to place a spray nozzle which I have not bought yet.
I'm stuck at this point: given the syringe diameter, the tube length and diameter, the pitch of the thread, and the motor steprate, how do I calculate needed steprate to have a certain pressure?
The following image is taken from this thread, I didn't make it.
Last attempt was to use Hagen-Poiseuille formula for every section of the device. The long tube, the syringe tip and the syringe body.
So my P2 is the pressure I need (0,5 bar) plus atmospheric pressure, am I right? Then after I use that formula and I can say that losses along the syringe body are negligible so that P ≈ P0 ≈ P1. Now that I have calculated the necessary pressure at the plunger to obtain the needed output pressure and flow rate, which is the next step?
I thought of use these calculated pressures inside Bernoulli's principle, in order to get the linear velocity at the plunger and so calculating the steprate from that one, which is straightforward. Does it make any sense?
EDIT:
What I need is an output pressure of 0,5 bar and a flow rate of 233 μl/s
How did you arrive at that number? I don't see that you've told us anywhere what the desired performance of this system is. In particular, the desired flow rate and associated pressure drop at the nozzle.
You seem to be approaching the problem backwards.
It is what I need it is not calculated.
I edited the first post. I still have to choose the spray nozzle though, but it will likely be a nozzle that can operate at those values. Do you need the complete numerical application of Hagen-Pouseuille formula?
Yes forgive my inaccurate thread title. It should actually be the contrary, calculating step-rate from pressure. I've been trying both ways during my attempts.
No, this problems is largely flow driven, not pressure driven because water (I assume water?) is incompressible. As you were told in the previous thread, this is a pretty simple geometry problem, matching the flow rate to the volume reduction of the syring and converting to the linear speed of the plunger.
Yes we are talking about acqueous solutions.
Okay, that was the first thing I did a lot of time ago:
ω = ( Q ⋅ 360°) / ( π r^2 p ∂°)
Where omega is the step rate [step/s], Q the flow rate [m3/s], r the syringe body diameter [m], p the pitch of the threaded rod [m/rev], ∂° the angle encompassed in a single step (given by the motor datasheet), and 360° obviously the angles per revolution [°/rev] ("per revolution" as "measure unit" was used for better readability of the formula and easier sums.
So I have everything I need as far as the syringe and tube is concerned. The problem is that spray nozzle specifications are given in terms of input pressure and output flow. So I really don't know how to choose the spray if I don't know the pressure. Moreover there esist devices like the one I'm making and they all provide the pressure out of the spray head.
In positive displacement pumps with incompressible fluids, the pressure will be whatever the system demands. There is nothing to calculate...
...Except as it relates to motor torque, which you haven't asked about yet. But one thing at a time.
Okay, so if I had to choose a spray nozzle what features should I look for? As far as I know spray nozzle are provided with operating pressure range, and minimum capacity, is that right?
Let's consider this one as example. It says:
0.19 - 46 L/min @ 0.7bar
Min. 0.4 bar
It means that it cannot output less than 0.19 L/min, if I've understood correctly. So if I pushed less than that with the motor by using the formula in the above post, wouldn't it spray at all?
Min. 0.4 bar
That link includes an entire performance table. Decide what flow you want, and at what pressure, then look up the nozzle size associated with it. The pressure is probably not very important, so 0.4 bar is probably fine...though note, the spray angle changes with pressure.
No, that's just a minimum rating. what probably happens below the minimum flow is the spray pattern becomes non-uniform.
Okay, let's suppose that I need I choose any of them, because the flow rate is what I need, 0.19 L/min for example, the one with 1/8'' thread size. This means that if I pushed with the motor a certain amount of water (like 100 μl) at 0.19 L/min, then the pressure at the spray will be 0.7 bar as written in the table?
Just to be sure. Thank you very much
Yes; the pressure just upstream of the nozzle.
