System Dynamics: A Qualitative Understanding
The discussion centers on the qualitative understanding of a spring-mass system operating in the x-y plane without friction or damping. The participant identifies three differential equations governing the system: one for motion along the y-axis, one for the x-axis, and one for energy. It is established that when the spring operates in its linear region, the equations can be decoupled, allowing for a closed-form solution. The participant questions the stability of the system under these conditions and explores the implications of coupled equations on the system's trajectories.
  • Understanding of differential equations in physics
  • Familiarity with spring-mass systems and their dynamics
  • Knowledge of linear vs. nonlinear systems
  • Concept of energy conservation in mechanical systems
  • Research the stability criteria for linear and nonlinear dynamic systems
  • Study the principles of coupled and decoupled differential equations
  • Explore the concept of periodic trajectories in conservative systems
  • Learn about the implications of damping and friction in oscillatory systems
This discussion is beneficial for physics students, mechanical engineers, and anyone interested in the qualitative analysis of dynamic systems, particularly in understanding oscillatory motion and stability in spring-mass systems.
Johnrobjr
I did read some of the posts on the topic. However, I just want to check my qualitative understanding without employing too much mathematical dynamics. If anyone has some feedback, this would be much appreciated.
The System.
A spring hangs vertically. There is a mass attached to it.
Assumptions
The motion is restricted to act in the x-y plane. There is no friction or damping.
Initial Conditions
The mass can be perturbed from its resting position (the origin, -y axis parallel to the gravitational force).
My Understanding
There are three differential equations:
one for the mass moving along the y-axis.
And, one the mass moving along the x-axis.
Also, the is one for the energy of the system.
Most generally, the equations describing the motion in the plane are coupled, and a closed form solution is not possible. However, if the spring is stretched only so that it operates in the linear region, and the pendulum is displaced only so that it is operating in the linear region...then the equations are decoupled and a solution is possible.
My question is under those initial conditions where the equations are decoupled, will the system be stable, assuming no friction or damping? I think it will degenerate, but I am not sure why.
Also, if the system is operating so that the equations are coupled then many trajectories are possible (perhaps infinite). Is this true?
It the system operates so that the equations are coupled then are there periodic trajectories that remain stable or will they always evolve to others with time?
The system has no external energy and the internal energy is balanced (gravity vs spring).
If there is no friction or damping, once the mass is stretched, it will keep oscillating forever.
Time has no role here, once you begin this oscillating there is no stopping it without an external force.
I still cannot understand how the motion is restricted to the x-y plane, it should only be restricted to the y plane along which the only two forces are (gravity and spring)
