MHB How to Solve a System of Three Equations with Three Unknowns?
  • Thread starter Thread starter mkelly18790
    Systems
To solve the system of equations a + b = 3, -b + c = 3, and a + 2c = 10, one approach is to first combine the first two equations to form a new equation: a + c = 6. Next, subtract this new equation from the third equation, a + 2c = 10, to isolate c. Once the value of c is determined, substitute it back into the first equation to find a, and then use either the first or second original equation to calculate b. This method effectively simplifies the problem into a manageable two-variable system. The solution process demonstrates the systematic approach to solving multiple equations with unknowns.
mkelly18790
How do I do:
a + b = 3
-b + c = 3
a + 2c = 10
Mathematics news on Phys.org
I would begin by adding the first two equations, and then you have the 2X2 system:
$$a+c=6$$
$$a+2c=10$$
Now, try subtracting the first from the second to get $c$, then use the first along with the value for $c$ to find $a$, and then once you have $a$ and $c$, you can use either the first or second equation from the original system to find $b$. :D
What do you find?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
