MHB How to Find the Cube Root of a Number?
  • Thread starter Thread starter NotaMathPerson
    Cube hand Root
To find the cube root of a number without a calculator, a long division-like method can be employed, which is effective for numbers both below and above one million. The user is struggling with extracting the cube root of 12,812,904 specifically. A suggested resource provides a detailed explanation of this method. Utilizing this algorithm can help in calculating cube roots for larger numbers. Mastering this technique allows for manual extraction of cube roots efficiently.
NotaMathPerson
Hello!
My book explained how to take cube root of a number withou using calculator. I managed to extract the cube root of number less than a million. But when its higher like this one 12812904. I cannot extract it.
Can you suggest an algorithm on how to go about this one? Thanks!
Mathematics news on Phys.org
NotaMathPerson said:
Hello!
Hi NotaMathPerson,
There's a method to find the cube root of a number, similar to long division mentioned at the following webpage. It might be the one you are looking for.
https://xlinux.nist.gov/dads//HTML/cubeRoot.html
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
