Taking the integral of xe^ax^2
  • Thread starter Thread starter ilikesoldat
    Integral
The discussion centers on solving the differential equation dy/dx = x * e^(ax^2) by integrating the expression. The correct integral is identified as ∫ x * e^(ax^2) dx, which results in (1/2a) * e^(ax^2) + C, assuming 'a' is a constant. Participants clarify the importance of recognizing 'a' as a constant in this context, drawing parallels to standard mathematical conventions regarding variables and constants. The ambiguity in the phrasing of the integral is also addressed, emphasizing the need for clarity in mathematical expressions.
  • Understanding of differential equations
  • Familiarity with integration techniques, specifically integration by substitution
  • Knowledge of exponential functions and their properties
  • Recognition of constants versus variables in mathematical expressions
  • Study integration techniques involving exponential functions, particularly ∫ e^(ax^2) dx
  • Learn about the method of substitution in integration, focusing on u-substitution
  • Explore the implications of constants in calculus, specifically in differential equations
  • Review mathematical conventions regarding variables and constants to avoid ambiguity in expressions
Students and educators in calculus, mathematicians solving differential equations, and anyone interested in mastering integration techniques involving exponential functions.
ilikesoldat
dy/dx=x*e^(ax^2)
solve the differential equation
integral of e^x=e^x
im not really sure how to do it when there are two variables in the exponent? i tried several things like u=x^2 1/2du=xdx then 1/2*int[e^a*u] results, but i can't take the integral without a different substitution since int[e^a*u] is not = to e^a*u.
the answer is 1/2a * e^ax^2 + C.. any methods to integrate this? several methods would be best
Think about how you compute \frac{d}{dx}e^{f(x)}
a is a constant, keep that in mind . . .
I solved it with a as a constant and got the right answer, but . . .
How do i know a is a constant? I can't just assume that can I? What is the proof for a being a constant
Because a is assumed to be a constant in these situations, just as how \pi nearly always represents the irrational number, but in some other cases, it can be mean something completely different, such as representing a product.
And if it wasn't a constant, then you can't solve the problem. So which do you think is more likely? :-p
Was the question just "integrate xe^{ax}" or was it to find \int xe^{ax}dx?
That makes sense but it still bugs me to just assume it is a constant :(
And to the other person, the question was
dy/dx=x*e^(ax^2)
solve the differential equation, so yes it would be integral of x*e^ax^2 dx (except you forgot the squared on top of the x in e's exponent)
thanks for everybody's help
The situation is no different than if you were told to solve dy/dx = a .
What's the difference?
HallsofIvy said:
Was the question just "integrate xe^{ax^2}" or was it to find \int xe^{ax^2}dx?
The second, \int xe^{ax^2} dx, makes it explicit that the 'variable of integration' is x ("dx") while the first, "integrate xe^{ax^2}", is ambiguous. Of course, it is a standard convention that such things as "x", "y", "z" are used as variables while such things as "a", "b", "c", etc. are used to denote constants.
If it were \int xe^{ax^2}da, it would be (1/x)\int e^{ax^2}+ C.
Yes, but without those standard conventions then we could just as well argue that a=f(x) in the integrand, just as the OP has done.
  • · Replies 21 ·
  • · Replies 105 ·
