What is the tangential acceleration of a point on a rotating crankshaft?
  • Thread starter Thread starter goober19
    Acceleration
To find the tangential acceleration of a point on a crankshaft with a diameter of 3.0 cm that decelerates from 2500 rpm to a stop in 1.5 seconds, the relevant formula is at = Dv/Dt. The discussion highlights the need to convert angular velocity from rpm to radians per second and to apply rotational motion equations, specifically relating angular acceleration to tangential acceleration. Participants suggest using the initial and final angular velocities to calculate angular deceleration, which can then be used to determine tangential acceleration. Additionally, the number of revolutions made during the deceleration can be calculated using the angular displacement formula. The thread emphasizes the importance of understanding both linear and rotational motion equations for solving the problem.
goober19
A 3.0-cm diameter crankshaft that is initially rotating at 2500 rpm comes to a halt in 1.5 s. What is the tangential acceleration of a point on the surface of the crankshaft? How many revolutions does the crankshaft make as it comes to a stop?
at = Dv/Dt
honestly I am really stuck on this because the only formula that I can find is this one. Any ideas on where to head with it?
For linear motion we have,
v = v_o + a*t
For rotational motion we have,
thetadot = thetadot_o + thetadoubledot*t
thetadot = d theta/dt thetadoubledot = d^2 theta/dt^2
You know thetadot at t = o and you know thetadot at t = 1.5 seconds, solve for thetadoubledot
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
