Calculation of coolant tank size required to feed multiple grinding stations
To calculate the required size of a coolant tank for multiple grinding stations, the total flow rate of 12 taps at 20L per minute must be considered, totaling 240L per minute. The tank design includes a height of 500mm and necessitates separate sections for dirty and clean coolant to manage metal fines. It's essential to determine the volume of coolant lost per hour and how frequently the tank will need to be topped up. A magnetic filtration system is proposed to remove metal fines, and the diameter of a cylindrical tank must accommodate the total coolant volume when machines are shut down. Accurate measurements of the coolant volume in the system are crucial for determining the tank's capacity.
Rob365
TL;DR Summary
calculating size of coolant tank required.
I am trying to calculate the size of coolant tank required to feed multiple grinding stations.
I have a total of 12 taps all with flow rates of 20L per minute. All taps would operate at the same time.
The tank would be open topped and 500mm tall.
The tank also requires a dirty side and a clean side to remove metal fines.
Rob365 said:
TL;DR Summary: calculating size of coolant tank required.
What are you trying to achieve? Provide a diagram of the system, and design deliverables. “Size” is too vague.
What volume of coolant is lost per hour?
How often will you top up the tank?
Can you use magnets to remove the metal fines?
Can the abrasive material be recycled?
I am unsure of volume lost per hour the coolant levels would be checked weekly and topped up as needed, we are using a magnetic filtration system to remove the fines I am trying to figure out the diameter of a cylindrical tank i would require to be able to store all coolant when the machine is shut down.
Then the flow rate is not relevant. You need to know the volumetric capacity of all the machines, pumps and lines. You can measure that by measuring the volume of coolant in the system when the tank is not connected. Pump it all out into 200 litre drums.
Likes erobz, Lnewqban and Rob365
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
