Tarzan vine Conservation of Energy
The discussion focuses on a physics problem involving Tarzan swinging on a vine across a gorge, emphasizing the conservation of energy principles. The key equations used are potential energy (PE = mgh) and kinetic energy (KE = 1/2mv^2). The challenge lies in determining the height 'h' to calculate Tarzan's velocity 'v' at the moment he jumps onto the vine. A solution approach involves using trigonometry to find the hypotenuse of a right triangle formed by the vine and the gorge, allowing for the calculation of the maximum height reached. The method successfully applies energy conservation principles to solve the problem.
bmarvs04
A 17 meter long vine hangs vertically from a tree on one side of a 10 meter wide gorge, as shown in the figure. Tarzan runs up, hoping to grab the vine, swing over the gorge, and drop vertically off the vine to land on the other side
PE = mgh
KE = 1/2mv^2
Since energy has to be conserved, I tried setting to two equations equal to each other. In other words, the kinetic energy he had as he jumped onto the rope, and the potential energy he has at the top of his swing when he isn't moving.
I got stuck because I can't find 'h', therefore I can't find 'v'
Thanks in advance
use right angle triangle to find hypoteneuse using 17 and 10 as the sides.
Then calculate the angle (so between the ground and the rope = between side length 10 and the hypoteneuse) using trig.
You can subtract the length of the hypoteneuse by the length of the rope, then use that length with the calculated angle to get the max height- 'h' reached by using trig.
Then apply energy conservation.
Thanks a bunch.. It worked perfectly
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
