Can You Solve This Uniform Circular Motion Task in Physics?
The discussion focuses on solving a physics problem related to uniform circular motion, with given parameters such as radius, period, and mass. Key concepts include angular velocity, which is constant in uniform circular motion, and the relationship between the period and the angle covered. Participants emphasize the importance of using trigonometry to determine x and y coordinates, as well as differentiating these coordinates to find velocities and accelerations. The centripetal acceleration and force are highlighted as crucial for understanding the motion. Overall, the conversation aims to clarify the underlying principles of uniform circular motion rather than simply providing answers.
bini18
I have a question for you how to slove a task in physic
So this task is about Uniform Circular Motion
r=4 m
T=6 s
m=1.5 kg angle=50 degree
I have to find as a distance
x=? y=?
velocity acceleration force
V=? a=? F
Vx=? ax=? Fx
Vy=? ay=? Fy
http://www.walter-fendt.de/ph14e/circmotion.htm - animation of uniform circular motion
I know the results but i need to know how that results come
A little respect never hurt anybody
No need for that language: it's only been an hour and a half.
I'm not going to give you the answers - just point you in a useful direction.
You clearly do not know what those equations mean.
Lets go back to the first post and go through the things you need to know:
r = radius: the distance of the object from the center of the circle
T = period: this is the time it takes the object to go right around the circle.
m = mass of the object
important concepts:
angular velocity: \omega = \frac{d\theta}{dt} ... for uniform circular motion, this is a constant.
That the object goes all around the circle in time T means that it goes through an angle of 2\pi radiens in T seconds so that \omega = \frac{2\pi}{T} radiens per second. At any time t, the angle is \theta(t)=\omega t
Starting to get it?
If you put cartesian axis on your circular path, you can find the x-y coordinates by trigonometry.
You get the x and y velocities by differentiating the equations for x and y wrt time, and similarly for x and y accelerations.
The linear speed that the object goes around the circle though is a constant - it is just distance over time ... and you know that it goes the whole circumference of the circle in one time period.
What's important though is the centripetal acceleration which is a_c = \frac{v^2}{r} The centripetal force is given by this times the mass. This is the force holding the object on to the circle.
You should be able to get the rest from there.
So anyway ... you feel better about circular motion now?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
